the alloy bushes jammed in the rear cradle like this serve the same purpose as the Noltec sub frame bushes.
Yes the end result is the same and NVH is very much the same anyway.
  • Replies 53
all
staying on tie rod topic lol
im in 3 minds
JJR
Tein
Kazama
i wanna know which ones would last a while and be best to use.
looks like JJR arent too bad, but would they last ?
hhmmm
also they look pretty dodgy lol
rocket and VPW keep the full range of replacement rose joints, i have a set of JJR ones in cats car but with QA1 ends as the originals lasted about 2 event's before gettng sloppy. I ran ikeya formula rod ends on my 180 with no dramas for 3 years....
A mate in QLD recently snapped his stock tie rods and then after "upgrading" also snapped his JJR tie rod in his drift A31. Not the best quality by the looks of it, currently replacing them with tein tie rod kit that includes tie rods/tie rod ends and spacers for more lock. rrp $359 through www.isc-performance.com.
Ryan
Any photos of the failures? I am amazed he snapped the std ones! Bend maybe, but snap? The material grade they use normally means they are very ductile....this is assuming he didnt right off the entire side of the car...in which case not the fault of the std ones :)
Ive got kts ends on ikeya rods at the moment
daily driving havent noticed any wearing yet but they havent been on long
might end up getting the ones dave has as I think they would probably pass regency down here
whats the point of you fitting them ?
you getting bump steer
or you just need new ends
if you want to do the rears do it properly and swap in a s13 non hicas rear craddle less hassle in the long run
its what Ive done
Edited by 1400r
I already have a diff in my rear with some bushes etc etc, so owes me too much money to swap to an S13 cradle. If anything i will go GTR that way i get all the alloy goodness, bigger shafts etc and then just get new shocks (again ;))
Yeh, i needed new ones so if im going ot be spending hundreds on Nissan OE, may as well spend a little less and get something that may end up better.
Im going to pull out my rears and make up some of my own :(
  • 1 year later...
There is also these ones http://www.tuneagent.com.au/public/merchan...Item.aspx?id=22, they also fit the R34's.
Australian mob plus they come with a 1 year warranty. Look to be of pretty good quality, and for the price you cant go wrong.
Just orderd some myself, so gonna see how they go.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
