I need some stagea front brakes which i'm told will fit on my s13 under the stock sr wheels. Not sure of the differences between S1 and S2, so would prefer pick up in sydney so i could trial fit them. I live at Thornleigh. mainly i'm after calipers but will take rotors too if in good nick
cheers
john
0428 910 025
https://www.sau.com.au/forums/topic/190682-wtb-stagea-front-brakes/
  • 1 month later...
Hi Dirtdrifter,
I have an 99 Stagea S2 RS4 S which I'm replacing the front brakes on this week.
I'm not sure of the condition of the rotors yet, but if you're still interested let me know.
I live in Canberra, but go up to Sydney frequently, or I can ship them to you.
cheers
john
0428 910 025
dude i have a s2 and 15inch wheels don't fit over my front brakes,you at least need 16's . i am unshure of the s1 but s2 definatly not.
