SOLD... DELETE TOPIC
Item:Tomei Poncam for rb25det series 1 engine
Age:4 months
Condition:BRAND NEW NEVER USED
Price:TRADE OR $750
To Fit:r33 Series 1 (What car)
Contact:Nick
Comments:I want to trade my s1 poncams for set of s2 cams because i recently upgraded to a s2 engine and never got around to installing them. if i can find anyone to trade then i'll sell it. They are Tomei Poncams 256deg with 8.5mm lift BRAND NEW NEVER USED Paid over $900 for them and never used
Edited by r33_nikolas
Age:4 months
Price:TRADE OR $750
Contact:Nick
Please call me ASAP on 0434625148 I have what you need, you have what I want
Cheers
These cams will suit any R33 RB25DE(T) made till 09/1997. They way to tell if they will suit is by the cam angle sensor (Mitsubishi = Yes, Hitachi = No).
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
