Went in for a tune of my RB26 the other day and had lots of problems...
Most are a easy fix but one niggling on is the fact that my d-jetro map sensors are bottom lining at 20psi and I'm told that they generally max out at 26psi...
Any ideas why this is happening?!?
Cheers
Simon
https://www.sau.com.au/forums/topic/190702-power-fc-d-jetro-problem/
where is the pressure source taken from? i have had issue's when not taking the source from the actual throttle bodys (bit of a pain but worth the effort)... hooking up to the balance bar tends to cause a few issues.
where is the pressure source taken from? i have had issue's when not taking the source from the actual throttle bodys... hooking up to the balance bar tends to cause a few issues.
the intake manifold just before the throttle bodys?!?
Edited by Cerbera
before head and butterflies or between plenum and butterflies? it should be between head and throttle plates as shown in install manual.
ah yeah so thats the scale then and correction
that doesnt mean your maxing the map sensors
have you got a data log of the run?
check out what voltage PIM1/PIM2 get to, if they hit 5v they are maxing
sorry to hijack ur thread cerbera but i thought since ur on the topic of D jetro's i got a quick simple question.
they only made these for the GTR right? aint none of these got GTST or GTTs?
You can modify the ECU loom for the R33 GTST to be able to use the D-Jetro. I Don't know if this is the same for the R34 GTT (probably depends on the ECU plug shape as much as anything).
yeah RB26 D-Jetro can be used in R32, R33 and Z32 (300zx) but R34 GTT has a totally diff ecu plug.
did you see my last post?
is PIM1/PIM2 actaully maxing at 5v?
took stupid thing for a drive last night and boosted in 3rd gear to 23psi and the PIM voltage read 4.867V
this was only just on boost as the car is only rwd at the moment and likes to smoke 265's when it comes on boost and female passengers tend to get scared!!!
is this classified as close enough to 5V?!? maxing out?!?
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
