After some "spirited" driving on the weekend my ATTESSA has decided to put most/all the power to the rear wheels. My dash light is off and the torque spilt gauge is working fine but 3rd gear fishies mean something is playing up.
Now I'm assuming that the transfer case is gone, which I'll just replace if it has but I'm crossing my fingers that because the fluid in the tank is a bit low (just under min) it may have got a airlock in the system. I know how to bleed the system and have some nissan fluid to do it and will try on the weekend...
But in the meantime am i just wasting my time because its definatley the transfer case or is it worth bleeding the system?!?
https://www.sau.com.au/forums/topic/190708-attessa-problem-r32-gtr/
well i did say spirited driving haha
oh yeah the other thing i did that might mess things up was switch the car from 4wd to 2wd while the atessa was working very hard...
would this have done anything to the computer etc to cause this?!?
sorry guys for butting in. I tried bleeding the ATTESA sytem when i first got the car. You have to disconnect the green plug at the kicker plate. It was damn hard and i coulnt disconnect it. Any tips??? As how to disconnect the plug easily? Cos i have topen up the line at the underneath the rear of the transmission. Cos i got a leak on it andd im trying to determine whete is the gasket or an O ring on the fitting. But before i take the line out i have to make sure that im able to bleed the system after. Lemme know. thanks
Yudy
The transfer case uses a wet clutch system. These clutch plates only have a finite life, and 10+ years is well and truly in the "finite" catagory.
When you rebuild the case you can squeeze some extra plates in there (along with a couple of extra "tricks") to give a really quick uptake. Combine this with an ATESSA controller and your R32 will be transformed on the track.
but i dont wanna put u to shame gav :rolleyes:
  • 3 weeks later...
ok i finally got around to bleeding the system on the weekend... its seems to be fine and have no air in it.
BUT
while i was changing it i noticed that the attessa pumps would kick in for no reason every 10 sec or so when car was just idling, you can clearly hear a relay clicking and then when bleeding from the nipple above the diff a tiny little burst would come out with what looked like air.
plus on top of this the fluid resivoir has the top section and then the bottom section, with a spacer between. in all systems other than mine the bottom section has a air space in it... mine doesnt
any comments suggestions thoughts?!?
Edited by Cerbera
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
