Ferrodo Might Not Agree Hanky Purple Widget 27
(random spam tactics)
OK now that i have your attention ive fitted some ferrodo's 4000s (i think) to the front of my gtst and they are hopeless.
I've lost a ton of braking power and they just dont seem to pull the car up at all.
The guy at repco said they are dustless and wont make the wheels look poo and preform really well.
After bedding them in and following the proper procedure they seem to just skate across the disc itself instead of biting hard.
When i washed the car the rotors turned a urine yellow colour which looks like its from the pads and the dust.
The wheels also look horrible even just after like 2 weeks of the new pads.
Has anyone used these ferrodos and found them to be poo ?
I run the DS2500's and find them very grabby and noisy on cold but awesome once they have some heat in them.
I think Danrex upgraded to these, maybe check with him (could be wrong).
Did you upgrade the rotors too or just the pads? :)
i used to used freddo ages ago in my previous car and ye agree worst pads EVER. i use Bendix ultimates after that and they are awesome. think they go for $120 for fronts and $90 for the rears and they work a treat. putting them in my skyline next week.
i've just put rb74 in the front and C2 (i think?) on the rears. never had any different to OEM but they are good enough for the mo. havent had a chance to give them a thrash yet. will get back with results
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
