hey guys i have decided to quit on my rb30det build up that i was doing and selling off the following gear,this was all going into a vl commodore and im not 100% sure what else it will fit without clearance issues! but basically its a full hot side package.
hks t51r kai polished front housing,cereamic coated rear housing excellent condition
extreme turbo manifold to suit rb26/t51r ceramic coated with wastegate flange to suit 48mm progate with screamer pipe (brand new)
oil lines to suit above (brand new)
4 inch to 3 inch dump/front pipe to suit t51r into vl possibly skyline (brand new)
all v band clamps needed for mounting
at this stage i would like to sell this all together, may sell seperate if no luck selling, $4500
all brand new
turbosmart 48mm progate $600
custom plenums creation plenum with billet throttle body $1000
9.0;1 cp pistons suit rb30det $1100
n1 oil pump $400
greddy adjustable cam gears $250
rb26 clear timing belt cover $100
arp main studs rb30 $250
arp head studs rb26 $350
rb30 argo rods $900
item is located in perth WA
my name is jason my mobile number is 0410 357 940 (please leave a message if no answer) i am willing to post at buyers expense but i will not post item until i receive full payment!
if you would like any more info you can email me at [email protected]
Edited by psi-addic
https://www.sau.com.au/forums/topic/190756-fsrb26-hks-t51r-manifold-wastegate/
  • 3 months later...
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
