Hey Andrew,
You can buy the hub new from any auto store for around $140. I believe the one to get is the VLT/R31 hub. The VL N/A hub is different, smaller from memory.
I'm currently running a VL N/A fan; its slightly smaller, less blades and slightly louder but I had it sitting in the shed and doesn't have any overheating issues so I'm leaving it on until it starts to leak.
Hey Andrew,
Yeah i tried one off the VL, the N/A one is alot smaller fan with less blades so i figuerd it wouldnt cool aswell. What temp does yours reach say sitting on the highway at 100kmh on a 30degree_+ day?
100km/h mine sits around 85degree's on a 30+degree day. Hit the a/c and it will creep to 87 but no more but mine does the same on a cold day.
I did have an aftermarket thermostat in it and made it run quite a bit cooler. In the low to mid 70's. But it took too long to warm up so I grabbed a new nissan thermostat and dropped that in to it.
In traffic it can creep to 90degree's but no more; prior to replacing the a/c fan with a 14" sblade fan and wiring the fan to come on when I hit the a/c button it would slowly creep to 100degree's in peak hour traffic when sitting around in what the amb button says 60degree's for a good 30+minutes.
Temps are stable and hardly vary be it cold or warm. They are always anywhere from 83-87degree's depending on load and road speed.
Andrew,
Sorry Ash.. but Andrew yeah its the n/a fan.
The RB30e N/A hub and fan can't be interchanged with the 8blade VLT/R31/R32/R33 etc Fan/hub. Simply won't fit.
I'll be trying a set of thermo's again once this hub starts to leak. I wouldn't mind pulling the rad out taking it to a wrecker and trying to match something up out of a fwd nissan thing. No doubt something will match and cool sufficiently. Years ago I ran 2x12" fans directly on the rad without a shroud, it was fine in weather like now but as soon as it reached over 35degree's amb with the a/c on and in traffic for 30mins+ the temp would creep and not stop. :S
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
