Hey Andrew,
You can buy the hub new from any auto store for around $140. I believe the one to get is the VLT/R31 hub. The VL N/A hub is different, smaller from memory.
I'm currently running a VL N/A fan; its slightly smaller, less blades and slightly louder but I had it sitting in the shed and doesn't have any overheating issues so I'm leaving it on until it starts to leak.
Hey Andrew,
Yeah i tried one off the VL, the N/A one is alot smaller fan with less blades so i figuerd it wouldnt cool aswell. What temp does yours reach say sitting on the highway at 100kmh on a 30degree_+ day?
100km/h mine sits around 85degree's on a 30+degree day. Hit the a/c and it will creep to 87 but no more but mine does the same on a cold day.
I did have an aftermarket thermostat in it and made it run quite a bit cooler. In the low to mid 70's. But it took too long to warm up so I grabbed a new nissan thermostat and dropped that in to it.
In traffic it can creep to 90degree's but no more; prior to replacing the a/c fan with a 14" sblade fan and wiring the fan to come on when I hit the a/c button it would slowly creep to 100degree's in peak hour traffic when sitting around in what the amb button says 60degree's for a good 30+minutes.
Temps are stable and hardly vary be it cold or warm. They are always anywhere from 83-87degree's depending on load and road speed.
Andrew,
Sorry Ash.. but Andrew yeah its the n/a fan.
The RB30e N/A hub and fan can't be interchanged with the 8blade VLT/R31/R32/R33 etc Fan/hub. Simply won't fit.
I'll be trying a set of thermo's again once this hub starts to leak. I wouldn't mind pulling the rad out taking it to a wrecker and trying to match something up out of a fwd nissan thing. No doubt something will match and cool sufficiently. Years ago I ran 2x12" fans directly on the rad without a shroud, it was fine in weather like now but as soon as it reached over 35degree's amb with the a/c on and in traffic for 30mins+ the temp would creep and not stop. :S
