This was taken directly from that site, www.r34gtt.net in the headunit install section, i saved the page for down the track, when i save the $$ to get my unit, hope it helps
1 - First pull out the ashtray and undo the screw behind it.
2 - Pull up the gear stick surround and undo the 2 silver screws at the bottom left/right of the storage bin.
3 - Using a thin flat blade screwdriver on the left side, prise out the 2 vents at the top of the console and disconnect the unit.
4 - Undo the 2 silver screw at the top of the heater controls.
5 - Pull out the heater controls, radio & stage bin (all in a cage together).
6 - Remove the radio from the cage (2 screws each side) and fit your radio.
7 - Using the following parts PC2-76-4 and PC5-87 connect your radio to the cars plugs.
8 - Refit going from step 5
Steve :P
Steve :P
It helps a lot thx mate
