Hey guys,
So i was sitting on my computer.. kinda bored.. and decided to go through threads and pics (mainly vic and photography section) from the forums and print up a lot of pics to stick on my wall in my room.
After time my fingers were killing me from all the blu-tack and sticking and i still got more pics to put up. :P
Check out the pic of my wall :D can you spot YOUR car? :P
If you cant find yours and want it added just post your best picture here and ill add it to my 'wall of fame!' lol
Leigh.
https://www.sau.com.au/forums/topic/190797-i-was-bored-and/
  • Replies 46
Posted Images
really? iuno how people are finding it weird and creepy :s might have to take em down n just leave a few of the highly modded ones.. seemed like a good idea at the time! needed a break from all my exotic car posters around my room
https://www.sau.com.au/forums/topic/190797-i-was-bored-and/#findComment-3435087
lol i was jus jokin... i'd usually go for posters from mags...
I can't talk... I've got two bus shelter posters (6 foot x 4 foot) of Optimus Prime and Megatron from the transformers movie on my walls.
https://www.sau.com.au/forums/topic/190797-i-was-bored-and/#findComment-3435100
actually it said it was low and needed replacing so i just printed off pics n shit till i had to put new ink in, so much for 'low ink' aye
cover the whole wall with skylines...... :D:P
now...its maggi noodles time...and possibly fast and the furious 1 2 and 3
https://www.sau.com.au/forums/topic/190797-i-was-bored-and/#findComment-3435106
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
