I have heard that microtech's are hard on fuel. From what ive read the wolf seems like a great ecu, especially for the money, but alot of people say to steer clear of it. IMHO thats because a lack of knowledge than anything else.
In terms of getting the standard ecu re-tuned, i really cant see any value in doing that. It costs $700 odd and your still stuck with the std AFM ecu
https://www.sau.com.au/forums/topic/19081-ecu-upgrade/#findComment-401349
The wolf offers closed loop operation out of the box. Means fuel ecconomy is easier to acheive at light throttle. It's also 'plug and play' (no chopping into wires and new harness requirements).
Microtech is a good unit. Mat (whatsisname) has one on his car tuned well , he is adelaide.
https://www.sau.com.au/forums/topic/19081-ecu-upgrade/#findComment-402149
You cant run the Microtech off the AFM. Wolf does offer this option but nobody seems to bother with it, they seem to go straight down the MAP sensing path.
With the Microtech, you can leave it in place for leaglities/motor registry inspections etc ,and/ or ease of installation.
But it wont be doing anything except perhaps (Repeat perhaps) cause an inlet restriction.
If you want to get Microect ask your installer if they could arrange a drive for you in a car that they have installed the same computer in.
Be prepared for maybe having to put up with poor idle, cold start, stalling when air con turned on, running rich etc.
Some tuners have the majic touch and can get it right first go, others need a few goes at getting the day to day aspects of an ECU working for you on the street.
https://www.sau.com.au/forums/topic/19081-ecu-upgrade/#findComment-402942
Matt just blew his engine. 5th and 6th cyclinders wer running lean supposedly.
Still Microtech are very good ECU
https://www.sau.com.au/forums/topic/19081-ecu-upgrade/#findComment-402974
what do you mean legalities? i was under the impression that if you had a microtech and a cop or epa saw it your farked. on the other hand the plug n play ones can come straight out.
https://www.sau.com.au/forums/topic/19081-ecu-upgrade/#findComment-403878
If the authorities pop the bonnet and see you dont have an AFM, (provided they are clued in) then theyll know your running some sort of aftermarket Map sensed ECU. MIcrotech will still be illegal, just not as obvious to onlookers.
I understand if you go to the trouble of getting your car emmissions tested with the aftermarket ECU then they are legal. Look at the CSV commodores that run Motec, they are fully epa compliant and legal.
https://www.sau.com.au/forums/topic/19081-ecu-upgrade/#findComment-404267
You have to get them fully engineered to be able to run aftermarket ECU legally.. a costly operation so not many people do it.
Its all bullshit really, because there is nothing to say an aftermarket ECU can't be equally as efficient as a factory ECU, in fact it is probably more likely to be so as you can better tune for the external mods.
If you ask me the laws need to be changed in this regard, but they're still playing catchup to the fact you can modify a car without pulling the engine apart.
https://www.sau.com.au/forums/topic/19081-ecu-upgrade/#findComment-404326
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
