Item: Nissan Skyline R32 GTS-t (turbo) 5 speed manual - Oct 1993 (One of the last r32s made)
Item Condition: Very nice condition
Price and Payment Conditions: $12,000 with safety cert unregistered, or $12500 with 6 months rego
Extra Info: The car has geniune kakimoto exhaust system, cusco coilovers, cusco strut braces (frount and rear), pod filter, nardi steering wheel, turbo timer, 18" alloys with 90% tred. Number Plate VIP32
Contact Details: PM me
Edited by XJ40
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
