Hi all,
Im planing to do this conversion around the middle of next year. But if funds permit i may do it a little earlier. Ill use the GTR rear dif and try get GTR brakes all round. My quetion is what box do u guys recomend as im not doing the AWD conversion i cant use the 6 speed box unfortunately :D How strong is the GTST box? as i want to do everything right the first time so when i have a bit more money down the track i can go for bigger power with fewer issues. Has neone done this conversion or have ne advice to give me it would be greatly appriciated.
Cheers
John
https://www.sau.com.au/forums/topic/19088-na-to-rb26dett/
haha yeah thats cool, i was always under the impression they were 6 speed?? oh well im not missing out on nething then, also a gtr half cut is around 6g's ive been told as a real approximate around 10g's give or take a few. but i will also need new wheels aswell, so im giving myself a 15g limit for when i do it so i should be able to do a few mods straight away aswell. from my current insurace policy they only quoted 160 bucks extra for the conversion, and im 17 rating 5!!! i made the mistake of not getting it in writing cause im sure id never get a quote like that again it must have been a mistake.
https://www.sau.com.au/forums/topic/19088-na-to-rb26dett/#findComment-401751
i saved since i was like 10, working at my grandfathers company, then when i was old enough i worked at maccas aswell, i started saving for a car before i even knew what a skyline was, i managed to put together 10g's and my parents gave me another 6. and by the middle of last year i was a very proud owner of a skyline, since then every dollar i have earnt has gone into my car. And after y12 im planning to take out a 15g loan and do the converion.
https://www.sau.com.au/forums/topic/19088-na-to-rb26dett/#findComment-401828
this might be a stupid question but why are you getting the extractors if you're doing the conversion next year? i hope you go ahead with the conversion, it would be good to see it done and that way i'll know exactly what needs upgrading so I can do it to my car once i finish uni :D
what age do you get your license in queensland? i get mine in less than 3 weeks!!
https://www.sau.com.au/forums/topic/19088-na-to-rb26dett/#findComment-402044
u get ur learners when ur 16 and 6 months and have that for 6 months then u get ur p's then stay on them for 4 years. Yeah i figured the extractors wearnt too pricey and i just wanted i little bit more performance from my car for now, the high flow insert also isnt too pricey and an apexi afc i can use with the new engine.
https://www.sau.com.au/forums/topic/19088-na-to-rb26dett/#findComment-402060
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
