Yep, C3 is the entry level license (= wearing "P" plates again:p ) C4 is basically for national series (supercars, nations cup etc) C5 is international, eg Baturst 24hrs/ Le Mans etc....
I've gotta tell you, it's much easier to get these in GT3 than the real world:D
Yep, Bathurst 24hr was requiring C5 = International class license. I think that is part of why they are having trouble finding enough local drivers. The C5 upgrade is on a similar basis to C4 upgrade - observed performance in national level competitions over a number of races.
Originally posted by PeakRPM
Duncan.
Corect if I'm wrong...But I think you actually need some sort of approval/expirence level to race at Bathurst ?
Yep thats sounds about right Peak,,,The real Bathurst requires some experience in V8 supercars ,,,,I'll find out for sure on Monday when my Boss gets back from Mallala....His son's doing Formula Ford this weekend. Go the Bosch Spectrum.....
Neil.
Both bathurst races just require a C5 license - but you don't have to have raced a supercar before - there's a couple of BTCC drivers coming over for the Bathurst 1000 race.
I think most of the teams just prefer someone who's driven them before coz they're pretty different compared to other touring car classes.
Originally posted by blind_elk
Kim didn't offer up an apology for bagging the flaggies coz his useless brother couldn't keep it on the black stuff, did he?
ROFL,,,,,Kim's a wild boy thats for sure. Did you know he punched Brad big time in the pits years ago......Wonder how long Bowe will last there????.
Neil.
Neil.
I must say I don't think quoting my own posts is a good thing,,,But The Bosch Spectum WON on the weekend,,,,GO MARK WINTERBOTTOM,,,,,Remember that name,,,,I told you 1ST..........
Neil.
Yes and No,,I'm wrong as well,, Duncan,,,A C2 is cool but you need 5-6 sigs on your licence in 1 year before you can run at Bathurst in a Supercar....The C3's what you actually need,,,,Marks still using his C2 with Sigs because it's cheaper at the moment and he's doing enough races to keep it updated.....Mind you to get those signatures,,,it's going to cost YOU big Money and I mean BIG money. I think leasing a FF for the weekend is about $15000 to $20000 and thats with out losing a wheel....$5000 for each.
Neil.
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
