Something Wrong
todd0
 Share
hey guys, have an r33 gts-t, had it for a few months now, it has a front mount, pod filter, and full exhaust, but it seems to be lacking in power, it launches when it first comes on boost, but after about 3000rpm it doesnt seem to be pulling like it should be, it and then sometimes kicks again up around 6000rpm, maybe im just bein paranoid but im sure its something, iv been reading around abit and read a post where the guy had, what seemed like a similar problem, some people mentioned it could be to do with the coils, or the cat, does this sound like that?
thanks guys
Hi.
I realise you are new and all. But a suggestion of good use is the search button.
This type of problem is common, and VERY well covered in a great amount of threads.
Just search for "rich and retard" "coils" "midrange" and you'll find heaps of information
Cheers
depending on how much boost ur running, but would u happen to be running stock fuel system and injectors?
ive heard alot of ppl complain about the car being "hesitent" when running high boost
i had searched for coils, but i still wasnt sure if that was it, thanks for the other suggestions, i wasnt sure what else to look for.
The boost is stock, same with the fuel system. hopefully il find my answers in the searchs, thankyou.
hey mate, try getting rid of the 2 stage boost that they have as stock. it will be running 5psi up to 4800rpm then jumps up to 7 or 8psi after that. look on the DIY section of sau on how to do it. give that a go and see if that helps.
Hi.
Cheers
in his defence if he doesnt know about R&R how can he search for it :P
Thanks 33drifta, il get onto that now and have a go at it. if that doesnt work. do you think something like apexi super afc, or turbosmart fuel cut defender would fix the problem?
in his defence if he doesnt know about R&R how can he search for it :rolleyes:
So if I may… in my own defence… that is why I gave the key search words to use to lend a hand to more information so that one may find lots more information that would be posted in this thread :rofl:
i dont need any defence, i just needed a push in the right direction, so i got rid of the 2 stage boost, it seems smother now, but it still kicks slight in the higher revs
Take it to a mechanic knowledgeable with Skylines. Unless you're mechanically inclined, he will be able to sort out the issue quicker than any number of posts on here and you randomly poking around could achieve. m2c.
 Share
