hey, yeah my car has overheated once, and I've refilled the water in the radiator. However i seriously require a mechanic who can help me out. Anyone can recommend me someone good and well price, or anyone here confident enough to just help me from past experience. Seriously need help. Only this problem with the car, so anyone who can help me out or direct me to a home mechanic would be great. thanks
bryanlee38
https://www.sau.com.au/forums/topic/19094-need-mechanical-help/
Dude, go see a radiator specialist and get your system flushed and pressure tested. It is very uncool to overheat an alloy head. Sorry I can't recommend anyone though, but it will be worth the money to ensure you don't overheat again or at least to know what the problem is. It could be much more costly otherwise.
yeah well. it didn overheat with like smoke going everywhere. i just saw the temp gauge pretty much at HOT. THen i open the radiator cap (after lettin it cool) and realise there was no coolant left. I've put tap water in there soo far, i want to make sure there is no leak b4 puttin coolant in there. I've done about 1000km's soo far to the coast and back twice, car temp has been normal. Should i just ignore the problem??? Or treat it seriously. that white box on the left side of the engine bay which the water goes too is half full. wat level should it be at? I dunno if the pump is working, engine clutch fan is working. i presume they r.
its strange that you have got no coolant left.. it could be your radiator is leaking or water pump is gone. You should always check your water/oil level at least once a week to make sure everything's fine.
here's a tip:
1) make sure that you flush out the tap water FIRST (unscrew radiator nut at the bottom of the car). You will have to mix the coolant with water into a pail... make sure that you get the right mixture. Too much or little coolant can be bad.
2) once ALL the water is flushed out, turn on the engine and let the car run for all 5 mins. During this time, continuously feed water into the radiator so that the rust is being flushed out by the running water.
3) lastly, kill the engine and screw the nut back on and fill up the radiator via the reservoir tank (white box). There should be an indicator on the tank, if not, about 3/4 full is enough. If you pour anymore, it would end up being spilled. When all this is done, turn on your engine and let the new mixture circular around the radiator. it MIGHT shoot all the way up to H for a while but give it a while to settle in.
it will cost you a fair bit if you get this done by a mechanic but I have done it lotsa times myself. It only takes 1/2hr and allows you to understand your car a little better too.
hope that this helps
GenesisR32
Well i went into supercheap today to buy some coolant. he told me it there was nothing to worry about because:
i bought the car a month ago, the previous owner just had the car sitting for about about 4 months, not turning on nothing. So yeah he said dont worry about it. He gave me this coolant booster thing, small bottle - only 500ml. He said just drain a little water and pour the whole 500ml bottle into the radiator - i told him i'm only keeping my car for 6 months. he said that'll do. I havent been able to find the plug to release the water - still searching. If i just left the tap water in the radiator, how long before it acutally does any damage to radiator - rust?
I know a good import mechanic in Brisbane. He is working from home at the moment for a bit of money on the side and has excellent prices and service. If you want his details mail me. He used to do all the work on my R32 and R33 and can pressure test the system for you and find where it is leaking from.
Even if the car has been sitting for a while it should not leak coolant. Also tap water in the cooling system for an extended period is bad. Especially Brisbane water that is very heavy in minerals etc.
Anyway my email is [email protected]
You should get it checked out and fresh coolant put in. Cheaper to spend a few bucks now than blow a head gasket or something from it overheating.
I seriously wouldn't listen to some guy at supercheap. Most of them are 16 year olds who've watched their dad's work on kingswoods when they were 2.
Just letting you know also about another mechanic, Gavin Woods, Auto Tech. He's an awesome mechanic who takes great pride in cars. He knows everything there is to know about skylines. I don't know about you, but I would rather take my pride and joy to someone who I can trust and I know they know what they are doing than some mechanic who goes "yeah... skyline hey *walks to grab instruction book off shelf*"
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
    • All clamps are oem    one question is , what is the bit at the top on high pressure pipe where it connectes to intake manifold and other side goes toward the engine( see item in red circle in diabram attached)   ? Seen some people stating that should be removed on boosted application and skyline is boosted from manufacture so little puzzled. Mine is around 23pwi (700 hpish)   also some state it could be the bonjo bolt crash washer so bought two washers
    • what do you mean dead platform? People buy older, out dated and less power cars on "Dead platforms" for over $65k all the time.
    • That is really nice! Very nice finish when you have an oven to do the crinkling nice and evenly!
