Rebuilding my RB25DET..
i have noticed that 5 out of the 6 pistons are number # 1 type and and 1 piston is # 2 type
refering to the manual i found that numbers indicate different bore size and piston to suit
any1 can confirm?
also i am going to be using RB26 Mehle forged pistons... and have been told by many performance shops to leave the bottom end
standard as i dont want much more then 300RWHP....
if i am rebuilding what should i get done? bores are in good condition.
was thinking or pistons/rings/clips, all new RB26 seals/gaskets, get head work 'like skim, valve stem seals, ect' , clean the block and head myself?! and give them a slight hone... n clean?!
i dont know i just want to make sure i do this right
PLEASE help
thanks
GaZ
https://www.sau.com.au/forums/topic/190945-rb25-rebuild/
Is your motor dead currently?
And why are you using RB26 forgies in a RB25?
300rwhp is totally within the limits of the stock motor. IMO $1400 pistson are a waste of money in it, same with spending any money on the head.
350rwhp is still within the factory motors limits with a good tune.
https://www.sau.com.au/forums/topic/190945-rb25-rebuild/#findComment-3437486
Mate just rebuild it to STD specs with a metal
head gasket should be fine.A little tip if you do
rebuild it put the water pump in a bucket of
water while you are doing your rebuild this is
to insure the seal doesn't dry out and leak
once you start the motor up after a period of
time.
https://www.sau.com.au/forums/topic/190945-rb25-rebuild/#findComment-3437551
