Iv got a no name forward facing plenum on my rb25det and im not sure if the air flow is even and would like to know if its worth putting on my soon to be rb25/30 so im looking for a place that can flow test the plenum.
Also lookin for info and a place that can help me with porting a throttle body(If it can be done) and porting the standard manifold.
Cheers
Dave
https://www.sau.com.au/forums/topic/190947-flow-testing-a-plenum-some-porting/
Im not sure i got it with the car but i like the look of it as it looks stock no brand names and its clean but if its has a shit flow il put the stock one on
only pic i can find very old and dirty bay lol
  • 3 months later...
I just called milton engineering and they told me that plenums cant be tested for flow rates to see if air is the same in each cylinder. They said my best option is to stick a sensor in each runner and get a dyno tune. If i go ahead with this(more research first) can i tune it to run the same in each cylinder from a power fc or is it just to see the reading?
Cheers for that il give them a call tomoro and see what they can do for me. I just took the plenum of and hade a look inside to see that it is a cut and shut job and that its been smoothed out to hide the job
Now i'm not giving you sh!t, but can you now see why your engine may have blown on a Specific workshops dyno?? Like you said you bought it like that, but i just don't see why people need to cut and shut things like that when they are playing with so much money, It's like cutting springs in a car, why? when they only cost a whole lot of F#$k all!!
The shortest most direct path is generaly the best as long as even flow is obtained to each port. Whats been done isnt a bad thing and certainly not something to get worked up about. I could maybe understand your response if someone did this to your car without asking.
Think about it........ The standard one was no doubt designed that way(eg in the middle) for a reason, Don't get me wrong on our RA40 3sgte race car we have it from the front, but we never cut and shut a working standard one, which is the way it was desinged for, What i'm saying is go out and spend the coin on a aftermarket one which has been proven to work, trust me, saves you in the long run!!
You said it yourself "as long as even flow is obtained to each port", clearly coming from the middle on this specific plenum was the way the flow was directed and made!!
I understand what your saying but spending money on aftermarket ones isnt always the best option, the best flowing plenum I've seen was made from a factory one. The main difference was the angle that the intake joined to the plenum and the overall size had been increased. Alot can be done with the right tool's/skill's.
Thats alright i coulda sworn in another thread someone was giving said workshop shit because there car had issues on dyno, and it had a plenum like yours!!
ok then if u think this is such a bad thing then why did boostworx the workshop that u go 2 recommend me 2 do this same cut n shut 2 my car if they new it was a bad thing 2 do which they said was a perfectly good thing 2 do and nothing wrong with it, plus thats not the reason for them blowing my car up on the dyno, i have taken my car 2 morpowa, willall racing, nisspeed, hi tech dyno and none of them have said it was a bad thing 2 do 2 ya plenum
so in other words u r paying out your own tuner
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
