oh also... theres a cutout GT-R with the turbos stickin off it... can you try to get the serial numbers off it? and someone there what cosworth and all those companies once rumoured to collaborated on the GT-R ended up contributing.
  • Replies 185
nothing... just think it rates highly in comedic value... tho whole time he was babbling on about the GT-R being the ooooltimate expression of Nissan's pipe dreams I felt like punching him on the cock.
plus he oversaw the split of the GT-R from the Skyline lineage.
Well ill thank him for seperating the skylines into "GTR" and "the rest", THEN you can punch him
As the title reads, ill be going to the show on Sunday to shoot the GTR. Picked up my DSLR D40X from my friends at Nikon tonight.
im so tempted to have a major dig at Rezz right now.
If there is anything you think i should shoot, let me know. We all know about the shape of the car and the engine specs and diameter of the wheels...
what shots would you like to see? Let me know!
Are there any cars that werent covered in other websites, for example...nah.i wont, like the new Lambo Reventon that you would like to see?
Ill be taking a ton of photos so let me know what you would like to see.
Well there is a rumor that in order to fit the two turbos under the V configuration, nissan had to cast the exhaust manifold & the turbine exhaust housing as one solid piece. Could you see if you can get a photo somehow?
Cheers
ive already told you munkster..im not going to punch Ghosn on the knobend...he might take it the wrong way.
the Reventon is one of the cars ill be taking shots of. I should be able to get shots of the inside of the GTR.
Munkey magic, were you serious about your requests or are you taking the piss out of me as well as Ghosn? :)
well i would love to see the rear mounted transaxle and transfer case, as well as anything from the motor. but I somehow doubt you will get under there. feel free to prove me wrong lol
LOL, if anyone has heard and seen my antics in getting into the paddock at Suzuka last year without a pass will know i am damn capable of Houdini like maneuvers..
Ill see what i can do.
cheers.
There is the cutaway GT-R there which shows it clearly but no closeup pics online yet.
I would be very interested in seeing more of the transaxle and the massive errr "nose shaft" from it!
Edited by Laurence
yeah interesting solution to the nose heaviness problem, I think a couple of cars have gone this way over the years like corvette, maseratti coupe etc. WIll make it a shit load easier to pull the motor in an out (and much harder for the gearbox/diff/xfer case)
Clear pics of the dash
Around the radio controls
Screen controls
Traction controls (that section above the gearknob)
Indicator stalks
Close up of speedo/tacho
Inside glovebox
These are all on the Nissan Press website already:
http://press.nissan-global.com/NISSANGTR/E...otographs2.html
Munkey magic, were you serious about your requests or are you taking the piss out of me as well as Ghosn? :(
I was actually quite serious about everything except Ghosn. I wanna see them suzuki girls they're rumoured to be sensational... and the new Honda CR-Z hybrid. Plus the cutout is really cool. one of the other guys took a walk around vid of it, but I'd love to know what turbo's they're using.
yeah sewid's link is awesome. the front and rear subframe detailed shots show that there has been surprisingly little change to the subframe design, they would be 90% the same as 32 gtr, lots of minor improvements obviously but the basic shapes and mountings are the same.
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
    • Aside from the fact it is likely fuel related if it is black, the symptoms otherwise sound like worn valve stem seals. Oil gets past the worn seals when the engine is off and burns when the engine starts. If it happens on deceleration while driving (puffs of white smoke) that is another valve stem seal symptom because oil gets sucked form the head into the combustion chamber under vacuum with the throttle closed. They can be replaced in the car if you have some way to keep the valves closed while working (eg compressed air into cylinders) but is much easier with head off.
    • Alright, fair enough. Expected as much. Possibly, yes. However the kit is apparently not including every single hose and it is out of stock too.
    • I sourced my silicone hose kits from Just Japanese. Their current link is what I posted above but supplier might have changed over the decades.
