where exactly did you get this 20%? Was it a number that just kinda popped into your head? Or was it a number you would pay?
Do you know how much an '04 CLK is here? have a guess. Do you know how expensive it is to own a car in japan - especially a luxury one and that Japanese people regularly move cars after 3 years, upgrading to something new - leaving a pristine car with 10 - 15k on the clock? Plus, the taxes for cars like that arent as ridiculously high as australia.
Plus, I can tell you over the past year Ive done my homework. Ive already factored in the prices for LCT, GST, import duty, shipping, insurance, dereg from Japan, reg in Oz and i still come out a long way ahead.
Even if i factor in 10% based on what you think Aussies would be willing to pay for a German car that was in japan instead of australia i STILL come out a long way ahead.
looks like a clear winner to me.
by the way, German cars dont depreciate nearly as badly as Japanese ones. Everyone knows that...except i hope for the GTR.
The 20% I just plucked out of the air dude, I have no Idea about prices of anything at all.... LOL , I have owned about 150+ cars in my short life....Suit yourself but don't say I didn't warn you .
When you compare prices in AUS and Japan , compare apples with apples, compare wholesale prices in Japan with same here , not wholesale Japanese prices with retail prices here .
Have you ever tried to sell a high price Merc in AUS ? Especialy one that was sold new O/S? When you do you will find out what I mean . I have done it before several times ..
By the way I wasn't including luxury tax because I was hoping you will buy it under the LCT threshold , if you don't you will loose plenty money !!!
Actualy luxury cars of any sort depriciate a lot more than run of the mill Jap cars here in AUS . If you want to know 4WD's hold their money better than anything else .I own a 2000 model Landcruiser, I'm about to replace with the new 200 series , I will get over $40k trade in for her and I only paid $69 k in November 2000 , find me a luxury car that will be worth as much as a % of the original purchase price.
Good luck with your venture and I hope you make heaps of $$$$
  • Replies 185
I think he means an ADM CLK vs a JDM CLK...
Yep, yep i see that now. missed it.
i think they will...especially if they can get one in similar or better condition for thousands less, wouldnt you agree? :) :sorcerer:
apples with apples. i hear you. Im still doing research. As it stands the LCT may not apply if i find the right car. i know how much it will sting if its over the threshold.,..57k wasnt it?
besides, before all that, i have to keep it safe and out of trouble for a year, then get it safely shipped to Oz. Once its there the old man, who deals nation wide in cars, mind you, will im sure find it a good home. Im also concerned about the ship hitting icebergs and all that...you know wharfies loosing control of the thing trying to floor it out of the container and putting it over the edge of the port...
:):blink:
shit, how funny would that be if any of that were to happen!!
    • Also, the cause of fuel spills and smells from the top of the tank is almost always the rubber hoses that are up there, not the tank seal.
    • 1. No, as you say you can remove the connectors and fuel lines. Before you do make sure you remove fuel pump fuse and crank the starter a few times to release pressure, and also loosen the fuel cap (just in case the tank is slightly pressurised) as it will pump out the lines otherwise 2. Not necessary but you are right, if it is the factory pump it is at risk of failing after 25 years....Changing it is not hard but potentially not trivial as you have to make sure you have the right pickup/sock for the pump to suit the tank, need to make wiring connections (crimped butt connectors would be fine) and have to mount/adapt the new pump in the right place in the cradle. Not impossible but don't start the job if you aren't confident. Also, the plastic nut that holds that seal in place can be really hard to remove. If you don't have a fuel nut removal tool it generally requires a big screwdriver or similar to bash the ring around a few times before you can get it by hand. Also the fuel lines can be very sticky on the tank lid fittings, hose removal pliers can help or if not twist the hose on the fitting (eg with linesperson's pliers) to break the seal before you try and remove it. Finally, mark the feed and return hoses so you don't put them on backwards and seal them with an m8 bolt to stop crap getting into the lines while working. Add a little grease in the threads of the plastic lid when you go to do it back up as a gift to your future self, and make sure you put it on evenly/not cross threaded.  Having said all that, most likely the lid just needs to be either tightened or removed and put back on without being cross threaded...the seal itself is usually pretty good.
    • Another weekend and another project I have questions about.... I bought a fuel tank sender O ring to install on the car because I'm quite sus on what I've got now.  1. No "whooosh" sound when opening fuel cap 2. If I fill up full tank, there will be a small leak under the car and it comes from the top of the fuel tank, dripping along the side. Stops after a short while 3. Hot days = 50/50 chance to get high as a kite inside the cabin if the car was in the sun for too long This is what I bought: https://www.amayama.com/en/part/nissan/1734279900 My plan was to just replace the O ring but I've got some questions: 1. Does the whole fuel pump assembly need to come out for me to replace the O ring?         Or, could I unplug all the connectors and fuel lines at the top, take off the twisty part (17343) and put in the O ring from the top?  2. Is it a very common thing for everyone to just change the pump whenever doing this?        I see the Walbro 255 gets thrown in a lot but I've got no issues with my pump so far. When I did the tune, I asked the guy to check my fuel pressure and he said there were no issues too. But is it just a good idea to change to the 255 anyway as the old unit may have been in there for so long? The 255 seems to be a direct fit for GTT (I got no soldering iron)
    • Normal speedtek issues, bin it and go cdoo# or 8hp. So many issues with these gearsets, a mate went through 3 rebuilds and multiple parts with heat, bearing and vibration issues.
    • I wouldn't go near them, they are rubber seals for a reason. Just chuck new cam cover seals, half moons and the spacers for the screws every decade or two. I add a really thin layer of silicone too and it seems to hold together OK
