I have recently lowered my car 1.75 inches all round with king springs. Unfortunately the tyres now hit on the strut everytime i take a corner fast, and the back end will dump down when i change gears fast.
The question is, will good shockers like biltzien etc. fix this problem by not having so much body movement that the suspension bottoms out?
any help would be greatly appreciated, thanx...
https://www.sau.com.au/forums/topic/19100-suspension-setup/
Sounds like your offsets are a little too deep; ie they place the wheels about 5mm too far inboard (assuming they are aftermarket jobbies).
Also, when you lower, you tend to pick up extra negative camber - when looking at the wheel front on the tops of the wheel tip in towards the body. A good camber correction kit or adjustment should fix this.
Just a note also when you lower a car - the stock shockers are put under a fair bit more strain as they are not 'matched' to the spring rates - if you can afford it would be wise to change the shocks too to a stiffer rating - when you say it dumps down when changing it seems like you don't have enough damping.
Hope that helps :D
https://www.sau.com.au/forums/topic/19100-suspension-setup/#findComment-401608
thanx ronin, yea there was no extra camber i asked the guys when i got my wheels aligned..
The tyrewall doesnt hit on the strut housing, there is around 1cm+ clearance there, but the top of the tyre scrapes on the part of the strut that supports the spring.
Because this is caused by excessive bodyroll on corners and big bumps, if i had uprated shockers/heavy duty would that stop this from happenin?
https://www.sau.com.au/forums/topic/19100-suspension-setup/#findComment-402794
Hippy: I'm not exactly sure.. I don't believe mine has any form of camber adjustment and it was sitting pretty damn low (enough to get canaried). It still handled pretty much the same at that height and my current legal height so maybe the coilovers are better at adjusting for that. I have adjustable (height & damper) Zeal Coilovers.
https://www.sau.com.au/forums/topic/19100-suspension-setup/#findComment-402852
i did the same as you. droped my R32 about 2 inches and after about 4 weeks of driving i had blown the standard shocks. The seals split and all the damping oil came out. it was like driving a pogo stick around, and can be fairly dangerous.
I replaced the standard shock absorbers with Bilsteins and they worked a treat, however be careful with how low you are going to run the car, because i found it possible to bottom them out on big hits. other than that it was a sweet ride!
The shocks cost about $1300 and you can use all the bits off your standards - boots, strut tops, bumpers etc.
not a very hard job at all.
https://www.sau.com.au/forums/topic/19100-suspension-setup/#findComment-402854
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
