Hey All, just thought I'd show some of my pics from the Tokyo car show, these are just the nissan ones for now...
Checkout how deep the crowd was for the GTR on the main stand.
Also, the car on the left of the GTR on the main stage features an R2 unit in the dash, which I guess would be handy for repairing damaged sheild generators when they break in battle.
Also, there was a cut-away pic of the GTR which shows its driveline, looks great! Gearbox is in the back for better weight distribution. This car ticks all the boxes for supercar!
Also, a couple of the skyline coupe. I think its new...
Cheers.
https://www.sau.com.au/forums/topic/191024-went-to-tokyo-car-show-today/
Just got back from my nearest dealer... Nissan in Tokyo told me they expect some where from a March to August delivery
and that there was a long waiting list to cover. So expect delivery of around June/July.
Heres a red one for some, especially you REZZ :P
Also check out the optional gunmetal rim and rubber!!
Interesting to see if anyone can actually sit in the back, almost impossible with a normal sized adult sitting at the front.
Also look at the plastic/carpet like guards liner.
Edited by N/A®
How a guy like Ken could get his hands on a GTR before i did is beyond words...
That is simply unspeakable.
never to mind. He's not going to be the only one...I just have to wait my turn.
Edited by m3gtr
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
