I have a TD0625G sitting around orginally bought for my gtt. Now that I have sold the car I plan to used it on a R33 GTR Im importing. How do you think of this turbo would work on a Rb26?
I don't really want to sell it since I will be losing money and it is a genuine Trust product.
I don't plan to get crazy 400awkw out of my GTR so I don't need a big single. 300awkw is all Im after with PFC, FMIC and injectors which is why I think this turbo should be up to the task and should be more reliable than the factory twins.
What do you think?
Thanks
Edited by BaysideBlue
https://www.sau.com.au/forums/topic/191062-small-single-on-gtr/
I'm all for seeing a decent medium sized single on an RB26. A mate of mine is actually first firing up his R32 GT-R running a built RB26 and a .82 GT3540R on it - probably bigger than a TD06 25G but the same kind of idea.
a good mate of mine who has a GSTS 33 with a Rb26 conversion (did it ourself) has put a turbonetics T3/T4 turbo on the car with injectors and a autronic SM4 with 2 Z32 AFM's (to make it less harsh on the road). we see about 270rwkw out of that car, and its deadly respsonsive, full boost at about 2900 rpm then it just rockets to the 8k limiter lighting the tires up. if i do a roling start with my GTR runnin 450awkw and hist gtst that car noses ahead cuz the power is lighting fast, but after that the T04Z kicks in and he becomes a spec in the rear view. but i can tell you that turbo is super responsive on the 26 engine, it nearly put us in a lantarn post cuz of the rear end constantly stepping out in 1st 2nd and 3rd gear, its just brutal.
Based on how kick ass the 25G is on a 25, i can only imagine its going to be an equally good thing on an RB26. I personally dotn understand why the 25G isnt used more often as a sngle on 26s
guess people usually stick to twin setup for medium power upgrade and big single for 600hp+
wow full boost at 2900rpm?? how much power was the turbo rated at? if he made 270rwkw im guessing its an 450hp turbo, only a guess but.
reason for asking I had a GT3240 on my gtt full boost at 3900-4000rpm and its rated at 550hp.
yea it comes onto boost quite heavy because of the smaller exhaust housing, but then again after 7200-7300 we are forced to pull timing cuz of the heat it begins to dail in to maintain the boost, that gives it somewhat of a soggy top end. but the midrange pull is just brutal, on semi slick radials it just tries to blow the air out of your lungs due to acceleration. the engine we run is the RB26, bored to 86.5mm using wiseco forgies and pauter H beam rods. the cranck was regrinded and ACL black bearings used allround. full ARP bolts and nuts all put together with surgical precision, i wanted to go perfect on this one so it took me about 4 months for the job. it has tomei lifters, jun springs and titanium retainers and tomei 254@ 9.15mm lift cams and to top it off, 0.5mm oversize manley gen II valves with a port job and a 5 angle valve job. I know i know, that turbo is choking the engine and not utilizing the power it is capable off, but after my bud built the engine invested in electronics and gearbox internals and differentials and respraying the car and bodykits etc he forgot the most crucial part, the TURBO, my wife had a new one that was ready to go on her EVO VIII and se sold it to him cheap, since then running on that till he saves up
I'd say thats more to do with the tune and subsequent cam timing not being as good as it could be.
Small / Medium single on a RB26, way of the future if u ask me :P
Custom GT35R with cams should net full boost by 4000 with a 430rwkw top end.
No one talks about these setups, cus they're so special - hahahah :teehee::)
Edited by GeeTR
t04z hit full boost by 4000rpm....
if you were looking at 300rwkw, go a well made externally gated gt3076r, torque monster!!!
i was acutally going to use this kind of setup on stockish motor, but decided to go nuts with motor and the Z for powa
Dont forget the non-pump fuel aswell for 430rwkw from a GT35
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
