Hi Guys,
I have some spare parts from my old motor:
Rb26 Block. It will need to be rebored to 87.5 as there are marks on three cylinders $650
RB26 Sump with front diff, $430
Rb26 Head, we need a bit of work, $500
Rb26 stock Intercooler again a little damaged, but still looks ok $150
GTR gearbox and transfer case, $800
RB26 stock Flywheel, $100
Items are located at Logan QLD.
Pick up only
Andy
0404 947 419
https://www.sau.com.au/forums/topic/191091-rb26gtr-parts-for-sale/
Hi Guys,
Pick up only
Andy
0404 947 419
What caused the damage to the engine?.
Have you had the block crack tested?
thanks
something went though three of the cylinders...a bolt or washer...not 100% sure.
havnt had the block crack tested.
  • 2 months later...
  • 1 month later...
  • 1 year later...
What condition is the cylinder head in?
judging from the picture of the head, one of the valve guides has snapped and obviously this has caused damage to block... and since the guide is broken, the head will need a bit of work done to it...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
