When I did my last service I noticed bits of thread from the sump on my sump plug.
It pretty much only holds on one or two rings of the thread now.
I am not driving it till this is fixed so...
What's the best way of fixing this?
could get a helicoil fitted or maybe drill out and retap but would need an oversized sumplug. Just ring a thread repair man he wil be able to fix it.
Weld your old sump plug in and drill and tap a small dia bolt hole into the back of it.
Thats if its quite large, i actually havent looked yet so not sure. O/wise as above get a helicoil kit from bunnings and helicoil it if theres enough meat. Not sure about having to go oversize, helicoil drills out oversize and the helicoil/thread brings it back down to original????
i just found a slightly larger bolt and forced it
its just a bolt man. it needs a new thread one way or another. if you replace with something else, cut it first so its not overly long so ther is no chance of interfering with anything
  • 1 year later...
This just happened to me. The thread on the sump is damaged and as a result the sump plug does not tighten.
Can anyone please give me some advice on where i can find a mobile thread repair man in south east Melbourne?
  • 3 years later...
Holy thread revival!! I've just had this problem with my 32gtr. I've been thinking about going the helicoil option however I'm worried about any left over metal filings left in the sump ruining my engine. Any thoughts?
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
