2a_title.gifspacer.gif■Main Specificationsspacer.gifSpecifications4WDVR38DETTGT-R / GT-R Black edition / GT-R Premium edition•MODELNissan CBA-R35•TRANSMISSION TYPEGR6 Dual Clutch Transmission••DIMENSIONSOverall lengthmm 4655Overall widthmm 1895Overall heightmm 1370Interior dimensions (length x width x height)mm 1750×1475×1095Wheelbasemm 2780Tread Front / Backmm 1590/1600Min. ground clearancemm 110•WEIGHT/CAPACITYCurb weightkg 1740(*1)Seating capacitypersons4(2+2)Gross Vehicle Weightkg 1960(*1)•PERFORMANCEMin. turning radius (curb to curb)m 5.7Fuel consumption rate10-15mode (MLIT screening value)km/L8.2Main Emission Control SystemVariable valve timing•OTHERSDrive system4WDSteeringElectronic controlled power-assist rack and pinionSuspension Front/BackIndependent double wishbone suspension / Independent multi-link suspensionBraking System Front/BackVentilated brake disc / Ventilated brake discTire Size Front/Back255/40ZRF20 97Y / 285/35ZRF20 100Yspacer.gif(*1)When SRS Curtain Airbag System, SRS Side Airbag System for Driver and Front Passenger is installed, curb weight is 1750kg, gross vehicle weight is 1970kg.
•The fuel consumption rate calculated under the given test conditions. The actual fuel consumption rate may differ depending on the condition of the weather, roads, vehicle, driving, maintenance, etc. it is driven under.
•The mode of fuel consumption rates indicated in this specification sheet are all 10-15 mode.spacer.gifspacer.gif■Engine Main Specificationsspacer.gif■Gear Ratio/ Final Drive Ratiospacer.gifModelVR38DETTNo. of cylinders, configurationDOHC/V6Cylinder bore x strokemm95.5x88.4DisplacementL3.799Compression ratio9.0Max. power outputkW(PS)/rpm353(480)/6400Max. torqueNm(kgm)/rpm588(60)/3200-5200Fuel supplyNISSAN EGI (ECCS)
Electronic controlled fuel injection system Recommended fuel/Fuel tank capacityLUnleaded premium gasoline/71 Transmission typeGR6 Dual Clutch TransmissionEngineVR38DETTGear ratio 1st4.056Gear ratio 2nd2.301Gear ratio 3rd1.595Gear ratio 4th1.248Gear ratio 5th1.001Gear ratio 6th0.796Gear ratio Reverse3.383Final drive ratio3.700spacer.gifPlease use the fuel listed as the 'Recommended Fuel' for this vehicle. The use of other fuel types may lead to vehicle trouble or failure. Please note, any trouble or failure caused by the use of other fuel types, will not guaranteed free of charge.spacer.gif•The engine power output values indicated in this catalog are all net power output values.
•Engine power output can be indicated as 'Net power output' or 'Gross power output'. 'Gross' values are estimations of power output of the engine alone. 'Net' values are estimations of when the engine is assembled onto the vehicle. For estimations of the same gasoline engines, 'Net' values are approximately 15% lower than 'Gross' values according to JAMA research.
•Please use unleaded premium gasoline for this vehicle. If unleaded premium gasoline is inaccessible, regular gasoline can also be used, although it may lead to engine power output reduction.
<SI unit conversion value> The unit conversion for converting conventional power output unit 「PS」 and unit for engine torque 「kgm」 to SI unit is as follows. The value is indicated only as and rounded off to the nearest whole number.
1PS=0.7355kW 1kgm=9.80665Nm
Not sure why it did not copy properly but read the comments regarding net and gross power.
http://press.nissan-global.com/PRESSKIT/NI...LISH/index.html
https://www.sau.com.au/forums/topic/191097-353awkw/
I understand that to mean 353KW at the engine, but once the engine is installed in the car. So its still an at-the-engine figure, but the its not just the engine sitting on an engine dyno.
https://www.sau.com.au/forums/topic/191097-353awkw/#findComment-3439329
  • 4 weeks later...
"gross vehicle weight is 1970kg."
thats my ONLY Criticism with the car. value for money, performance etc - all amazing..but i dont see how this could be flung around a track at a car that weighs more than an AUdi A8....
sure its fast..but imagine how much faster it would be if it were 1400 - 1500kg...it would slay pretty much everything...
even with a "lightweight" version the max they are going to take off it is 100kg (see Superleggera and Scuderia F430 weight reduction)...its still not that much...
it depends..if its a GT Cruiser, that weight is fine...but i dont see many GT Cruisers with engines this small...
still..its getting the numbers...but the weight thing is the only thing bugging me about this car..
https://www.sau.com.au/forums/topic/191097-353awkw/#findComment-3489447
I'm sure you don't understand 'gross weight' means. :)
https://www.sau.com.au/forums/topic/191097-353awkw/#findComment-3491475
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
