Just wondering if anyone has replaced these 3 guages with after market ones that read more accurate.
also would it be possible to change the oil pressure guage in dash with the volt meter guage in the centre console? vice-versa
I would like to put oil pressure, oil temp and boost guages in that read accuratly in the centre console,
cheers
James
https://www.sau.com.au/forums/topic/191105-r32-gtr-centre-console-gauges/
Yes, see the Defi range of guages.
Um, you need the gauges you look at to be in the instrument cluster, not the console. If I had my choice I would flick the front torque gauge & the fuel gauge to the console & put the boost & oil temp gauges in the instrument cluster.
But anyway they look roughly the same size, but the wiring would be a bitch to sort out. Not much room behind between the printed circuits & the gauges for messing about.
Best bet is if you are worried about this stuff is to get a proper data logger & a warning led for when stuff goes outside the parameters eg too high oil temp or whatever.
  • 3 weeks later...
3 x defi's
Question about removing the stock 3 piece gauges; Ive taken of the front fascia and unscrewed the metal frame that houses the Aircon and the stereo, but I cant seem to get the gauges to slide out... they seem to be stuck behind a piece of black plastic which I cant see the bolt points for.... can anyone give me a heads up how to do this?
Thanks!
-Dohmar
mine.. they look shit in this photo but really turned out great.
I used the standard plastic bezel from the stock 3 guage cluster to give it a stock look. Guages are 52mm autometer's.. or autoguages i cant remember. which ever is the cheap ones.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
