The bore is the same for the Rb25, 26 and 30. The diff is the stroke between the three.
It is posible. The rb30 Crank is nitred. I remeber reading something about the rb25 geodgen pins sitting higher (hence lower CR) than on the rb30 pistons. You could use all the rb30 internals in the block. Not sure about this. But definately worth looking into.
There are stroker kits available.. but for stupid amounts of money! And for turbo applications..
Pretty much the easiest, cheapest and best is to just do an RB30DE conversion. Its not a bad NA conversion for all of ~$500 or ~$1200 if you want a good basis for a solid NA car..
http://www.skylinesaustralia.com/forums/t186051.html
Thats my plans.. Run down on pg 2
Can someone shed some light on if it is possible to put RB30 Internals into an RB25 block?.. Saves A SHITLOAD of work for me.. Its an interesting option. Saves me the legalities of swapping from a 2.5 to 3L, front diff adaptor, VCT piping, timing belt, relocation of pullies..
lol.. sorry for hijacking your thread.. but its an interesting prospect!
Edited by GTS4WD
https://www.sau.com.au/forums/topic/191153-rb25de-build/#findComment-3441221
np u can hijack.........person i was speaking to wasnt sure if the 30 rods or 26 had to be used,
i have to get in contact with hioctaneracing andget actual details. As u said it saves the hassle of blue slips and stuff that would be required with the engine swap, was considering supercharging it so it would be an Rb28des..............food for thought!!!
https://www.sau.com.au/forums/topic/191153-rb25de-build/#findComment-3441511
If you want to increase Capacity, as before, RB30DE is the easiest.
You can use the whole rb30 bottom end, crank, rods etc. etc.
There is a .pdf file floating around, I can send you it if needed. Its a clear and simple build of an RB30DET. Which can easily be used to make an RB30DE
Just a thought, If you use an RB30 crank, rb25 rods and pistons, and you get a 2.8L.. the other 200cc's must be atributed to the rb25 geodgen pin sits higher towards the top of the piston compaired to the rb30 which sits further away from the face of the piston?
I dunno.. just an idea.
https://www.sau.com.au/forums/topic/191153-rb25de-build/#findComment-3441778
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
