hey guys,
had this as an on going project for ages now (R32 GTS4: RB20det to RB25det conversion), money issues have been holding me back badly. So when i had the oportunity to drop her in today, i was as excited as a dog with a shmako. Sadly though we failed. Reason being is we tried to tackle it by leaving the gear box in and trying to lower the engine in an join it up. But it was too hard to get the shaft in and line everything up. So now it looks like the gear box will be coming out :P which sucks because i dont know how im going to get the tail shaft off the gear box with thoes nuts being so freakin tight!
Here are a couple of pics:
Also have any of you here tried dropping an engine in with the gear box still in?
https://www.sau.com.au/forums/topic/191155-today-was-drop-the-25-in-day/
yeah its much harder but not impossible... you need to be 100% sure that the clutch is alligned first (use an aligning tool) otherwise you'll be there all day and get no where. you also need to make sure that the box angle is the same as the engine angle so that the shaft goes into the clutch true and straight... its a combination of getting a few factors right and then it all just falls into place.
good luck shutting the bonnet with that turbo too :P
I have personally experienced this mans blood sweat and tears.. more of the first two. So many problems along the way.. nothing went right for a while there but ..
finally its close to being done. Id love to help out cous but so friggin busy!
make sure your new spigot bush fits on the input shaft of the gearbox.
Make sure the gearbox is not in gear.
Make sure clutch is aligned properly.
Also helps sometimes if your engine mounts are loosened off.
Make sure your engine crane is holding the engine at the right angle, with the right amount of reach.
Dropping the tailshaft out is easy?!
I have assed around for hours trying to get an RB on, and sometimes they go right in... sometimes you will only get it so far, then you have to use gearbox bolts to pull the rest of it up...
Hope it helps in some way.
ps take that friggen monster snail off! why u need that on before its in??!!!
Edited by HRthirtyone
good luck shutting the bonnet with that turbo too :)
hey simon,
cheers mate, a crack at it all again this morning after i wake up. i have a rostered day off so ill try and make use of it. the bonnet will shut :P same turbo set up was on the old motor.
Mate you should be able to put the engine back in with the gearbox in the car. ive done it plenty of times. what you having the most trouble with?
maybe the fact that i dont have little japanese hands :O no, really i just couldnt even get the clutch in front of the shaft, the engine just tries to sit on everything, everything gets in the way and i end up trying to keep 5 things clear so i can lower the engine down further etc. im going to try again this morning at about 8am.
all good luke, i understand. besides you have what 6 import projects happening now? haha, you crazy bastard.
cheers mate
mate its going to be a good thing.
Take your time you will enjoy it more.
ill enjoy it when its actually in an functional and i can appreciate driving the thing a whole lot more knowing how much work i put in to it.
yea shaft fits, was in neautral, clutch is aligned properly (used a shaft dummy). I dont understand what you mean about loosening the engine mounts off? the thing is dangling from a crane, doesnt everyone mount it to the gear box before they worry about the other to engine bay mounts/??? :)
dropping the tailshaft out is easy i know, but you havent felt how tight the bolts in mine are :) theres 2 that are like in possible! think they need to be drilled out.
and the monstor snail will be a little to hard to put on once the engine is in. ive tried taking it off the old engine before and it was no fun at all.
depending on whether the rb25 came from infront of an auto trans check that the auto spigot still isn't in the rear of the crank.
ryan
yea it came from an auto, but i have already removed the auto spiggot and replaced it with a manual spig. cheers
IF there's a will, there's a way... I admire what you're doing... wish I had the know-how to do something like this. Amazing.
Is that a T35 Turbo I see?
cheers mate, really i knew not much at all before all of this. i just threw myself in the deep end about 5 months ago and started pulling stuff to peices until i got to where i am now. i have learnt so much in such a short time and its bein a really enjoyable experience. i know if i ever had to do this again it would be 600% easier the second time.
the turbo is a GT3540R
hey man
there is such thing as a clutch alignment tool, the best tool i have ever made was when i cut the front shaft off the front of my Nissan Blue Bird gearbox which i would put in the clutch and slide into the spiggot bush then tighten the clutch and make sure the shaft can slip in and out easily then your set for putting the box in properly in the car, it has to be nearly 100% to slide in first go.
hey man
yea i used one of thoes plastic dummy shafts to put the clutch on. im wondering though if there is going to be an easier way to be sure the shaft and the clutch will be at the same angle and will just slide in. or will i have to pull the engine back apon failure, rotate the shaft slightly then try slide it back on. I think i might take out my power steering and air conditioning because they are really in my way
where are you ?
i would lend you my shaft, but there would have to be a deposit left. I will go insane without my shaft on my next box removal job.
You need the shaft from a box itself, i had to sacrifice a old 4 speed box to get it but it works on all RB engines as well.
Yep that clutch alignment tool is such a big help!
Engine is looking good man, and that is one big fkn turbo! 3540 looks heaps big when sitting up against the RB25 out of the car.
How much power you hoping for, and are you just going to REMAP the standard R32 ECU or run an after-market stand alone?
Looking very good, hope you get it in and running soon, but like everyone said don't rush. Do it once and do it right!
Edited by abu
you need to jack the car up higher (so that you can alter g/box hieght with a econd jack). You can loosen the xmember bolts to give you an extra inch if it is close. You in Melb?
So much easier with a hoist.. we always take the box out first. Pretty much have to drop the engine crossmember almost all the way off to get enough angle to get the gearbox in and out.
Must say I would imagine it is a hell of a lot easier wiggling the box about to get it in than you having to wiggle the engine!
Good luck!
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
