where are you ?
i would lend you my shaft, but there would have to be a deposit left. I will go insane without my shaft on my next box removal job.
You need the shaft from a box itself, i had to sacrifice a old 4 speed box to get it but it works on all RB engines as well.
I'm in Adelaide, but na thats ok mate. the clutch is aligned fine. cheers anyway. i just used the plastic dummy shafts that i bought from a clutch shop.
Yep that clutch alignment tool is such a big help!
Engine is looking good man, and that is one big fkn turbo! 3540 looks heaps big when sitting up against the RB25 out of the car.
How much power you hoping for, and are you just going to REMAP the standard R32 ECU or run an after-market stand alone?
Looking very good, hope you get it in and running soon, but like everyone said don't rush. Do it once and do it right!
hey abu. cheers mate, yea it has a .7 compressor housing and it does look pretty big. was extremely laggy on my old RB20det set up. Hoping for a better spool now that its on the RB25det.
I'm hoping for no more than 250kw at the rears (With AWD fuse pulled out). I'd be more than happy with this sorta power, anything more and i dont know if id be able to financially back it up with all the repairs it would need every few months :glare:
I am hoping to use the same WOLF 3D V4+ ecu that i was using on the old set up. Ive been told it is compatible with the 25 loom. If not then id be happy enough with a remapped 20 ecu.
Also, i dont mean to rush but you can imagine how keen i am to just throw it in and drive away at this point :rant: but yea im doing it properly, atleast i think i am with this being my first proper engine conversion :kiss:
Cheers abu!
you need to jack the car up higher (so that you can alter g/box hieght with a econd jack). You can loosen the xmember bolts to give you an extra inch if it is close. You in Melb?
hey URAS, i may sound stupid but ive never heard of an econd jack? is this just like a hydrolic scissors jack or something? and no im in Adelaide. It seems most of the SAU boys are from melbourne. :(
cheers mate
So much easier with a hoist.. we always take the box out first. Pretty much have to drop the engine crossmember almost all the way off to get enough angle to get the gearbox in and out.
Must say I would imagine it is a hell of a lot easier wiggling the box about to get it in than you having to wiggle the engine!
Good luck!
cheers bubba buddy. Yea i'd give my left testicle for a hoist at this point. I'd also give money, but i dont have any. So if i get the oportunity to use a hoist, my left nut will just have to go. >_<
Cheers bubba
i swapped my 25 out with the box attached, without the car jacked, or the crossmember dropped..
ive helped a friend of mine swap a 25 in a 33 aswell with the box attatched, that is relatively easy. Without trying to sound rude, comparing your engine swap with my conversion, my conversion is alot trickier. you only have 2 shafts to deal with (tail shaft & box shaft). I have 5 (left drivers side, right passengers side, front drive shaft (box to front diff), gear box shaft and the tail shaft.
I think there's a bit more room in a 33 engine bay.. zertek also has a 4wd sump attached :P
very true. the 4WD sump is making things very crammy. I'm confident i will make this happen on my second attempt though. At the moment i am removing some things from my engine bay to make a bit of extra room. and also next time i will lower the box down to make angles a bit easier to deal with.
Cheers again bubba
URAS means using a second jack under the box to jack it up more... it would make a huge difference!
oh woops lol, i see he just spelt second with out the 's'. my bad :laughing-smiley-014: i thought an econd jack was some kind of fancy jack id never heard of. :)
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
