Just looking for ideas, my car is not making the power it should be and hesitates at higher rpm when full boost hits. I have a hi flow turbo and thought this could be causing a boost cut but its only hitting 13psi max and was doing it with the std turbo at 10psi as well. The afm meter has been replaced and spark plugs changed.
im thinking that it could be a knackered fuel pump or maybe a coil pack?? any help would be appreciated
https://www.sau.com.au/forums/topic/19117-rb20det-breaking-down-at-rpm/
Similar problem to what im having at the moment. Ive also changed plugs, fuel filter, put a front mount on, and today i tested another computer, and setup an oil pressure guage to measure my fuel pressure and was also fine. The only things it points to now are one of the sensors is faulty, read this thread and do the diagnostics and see how it comes back, im guessing its a crank angle or knock sensor playing games :)
http://www.skylinesaustralia.com/forums/sh...&threadid=19018
Let me know how it goes, im doing mine tomorrow night :)
cant find that link dude?
did the fuel filter today, getting a new fuel pump soon but have to put that on hold because the car has started making the same sound it did when the old turbo was dying :) (a high pitched scream/squeel) im hoping its a gasket, only one left is manifold to head, changing it tomorrow fingers crossed. had nothing but bad luck thus far
let me know how you go with that cheers
That link is there, but it was under the topic Auto RB20 ecu on a manual or something like that by me. I did the diagnostics and it came back with a faulty knock sensor which would make sense why my performance on my car is poor. Have you found that after 5500rpm it looses a noticable bit of power?
The hesitation at high rpm is probably due to an over rich mixture and this seems to be a common problem with these engines. We found that at around 10-12psi mixture strengths of 10:1 are not uncommon and this causes the engine to flutter at high rpm and causes a noticable decrease in power, ideal A/F should be about 11.8:1 to 12:1. Re gap your plugs to .75mm,we have found that NGK BCPR6Es11 plugs to be about the best.It probably wont be a coil as this is generally indicated by a droped cylinder at idle speed not a high rpm miss.
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
