im after a new head deck for my R33 series 2, it come with a 10 stacker sony head deck its a 1998 model dont know if thats normal lol. but yeah i would prefera double dim just wondering if any one has any pix of theres and any one have a clue how much a decent brand like pioneer and maybe some pioneer 2X 6"9's and 2X 6" fronts i could search but im so god dam noob lol and tired
this is my head deck now
Probably best to get 6.5" for the back and front as you will have to cut the parcel shelf to get 6x9s in there.
Factory, R33 have 6.5" so they will almost just drop in.
I'd say maybe a 4 channel amp to run the speaker for awesome sound, 6.5" splits in the front doors (tweeters), 6.5" speakers in the parcel shelf and the DVD head unit work work mint.
Not sure on how much a PIONEER double din screen is, but brand new the single din ones are about $1,000 - $1,400 and 2nd hand about $650 - $1,000.
I have seen 1 x double din head unit for sale, brand new selling for about $1,300 actually. I will see if I can fidn you the link for you.
Hope that helps.
Here is the link to the double din DVD player: http://calaisturbo.com.au/showthread.php?t...ght=pioneer+dvd
thanks allot for the link touch screen so sexy lol but i dont think ill buy that 1, ive been screwed over a bit with buying shit off the net lol and the info on the speakers is great thanks allot much love lol <3
done several. needs a small trim panel made to sit neatly but its a drop in either way.
what do you want to spend on it. ( may be able to help :)
umm around 3k all up so not that much including the dvd player head deck and all. what would u suggest?
this:
http://www.neltronics.com.au/AVN650.htm
that does what you ask.fits in under the $3k mark.
wat happens if my gf wants to watch a dvd while i need to use the gps :P lol my phone has gps on it all i needs, umm im after a single din for around 1k
ps thanks for ur help
thanks for all your help but i just got the http://calaisturbo.com.au/showthread.php?t...ght=pioneer+dvd
for $1000 dont know why that guys trying for 1.5 when i bought mine strait up for 1k, and yeah got soem pioneer 400 watt 6"9s coz i had 6" all round in the back and they were shittt! and got some 6" for the front pioneers all up spent 2k so far next is the 4 way amp and sound deadining shit for the doors
6x9's are a cheap mans replacement for a sub, 6" and a sub will sound a heap better.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
