do any of you guys use ems stinger?
have you had any probelms?
i think my ems, is causing probelms for my car. i dont think if it's the stinger, but i've been having some trouble with my cold start.
it seems like when it's cold, the car runs rough, but once it warms up, it runs a whole lot smoother.
the spark plugs also always foul up.
do any of you guys have a stinger and have the same probelm?
i might be thinking of buying a new computer if i'm sure the probelms are from the ems stinger.
https://www.sau.com.au/forums/topic/19120-probelm-with-ems-stinger/
I have a Stinger.
Is yours in stand alone or piggy back mode ?? Mine is in piggyback mode with the std ECU - no problems with cold start.
It idles a bit higher than normal and fuel economy is ordinary (300kms per tank)
I did have a problem with the igniters and the EMS - EMS had to come out and modify the unit before the car would start.
However, all that said - my engine lost two cylinders a while ago. I don't know if was anything to do with the Stinger, but I don't trust it any more - So I'll be getting another ECU after the rebuild.
Dunno of that helps, but thoght I'd convery my experiences.
Cheers,
    • Best practice for any track day should be Bleed brake fluid, inspect rotors and pads maybe even flip pads if they are prone to tapering.  Quality pad (project mu, endless, hawk, winmax, ap), Good high carbon content rotor (dba4000/5000, Ap, projectmu), Quality fluid, Good air supply over the rotor and caliper are all required for best performance at a track day no matter the car.  Even the bedding in of the pad and rotor is key to longevity. I've seen so many rotors destroyed on their first track day due to it.
    • The hardcore tracks1ut guys I know would flush their brake fluid every 6 to 12 months depending on the amount of track work they did. Unlike most of us SAU guys, probably flush it once a decade 🥲
    • Now that these are NLA, I suspect the answer is going to be to 3D print the plastic bit and glue on some felt or something to replace the brush. I have one or two of them (new) in the shed to go onto the car at some point. I could put some effort into measuring them up and could attempt to draw up the printed part in FreeCAD, if there is interest.
    • Hey team, the R32 ones look different to the R33 and 200SX ones. Also they're sold out on Amayama, looks like some dealer cleaned up the stock.
