do any of you guys use ems stinger?
have you had any probelms?
i think my ems, is causing probelms for my car. i dont think if it's the stinger, but i've been having some trouble with my cold start.
it seems like when it's cold, the car runs rough, but once it warms up, it runs a whole lot smoother.
the spark plugs also always foul up.
do any of you guys have a stinger and have the same probelm?
i might be thinking of buying a new computer if i'm sure the probelms are from the ems stinger.
https://www.sau.com.au/forums/topic/19120-probelm-with-ems-stinger/
I have a Stinger.
Is yours in stand alone or piggy back mode ?? Mine is in piggyback mode with the std ECU - no problems with cold start.
It idles a bit higher than normal and fuel economy is ordinary (300kms per tank)
I did have a problem with the igniters and the EMS - EMS had to come out and modify the unit before the car would start.
However, all that said - my engine lost two cylinders a while ago. I don't know if was anything to do with the Stinger, but I don't trust it any more - So I'll be getting another ECU after the rebuild.
Dunno of that helps, but thoght I'd convery my experiences.
Cheers,
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
