Hi guys
Yesterday I went to Sandown for the day and have some queries with the handling.
The car seems to be nosing over and pitching a lot to the front right, and really chewing out the outside of the tyre. Also not great on turn in, and getting a bit of understeer.
Any suggestions for set up?
The current list of parts / settings are as follows:
Ohlins adjustable shocks
F 8kg R 6kg springs
Ride height 355/350 (ish) front and rear
Whiteline front and rear bars, set on mid for both
Front toe / camber / castor - 0 / 1.5neg / 5pos
Rear toe / camber - 0 / 0.5neg
Is it under damped?
Thanks
https://www.sau.com.au/forums/topic/191217-suspension-set-up/
I'd be inclined to say more camber front and rear, min 3 front 1-1.5 rear as it sounds like you are rolling over on the outside wheel a bit
I like toe out on the front but i have a gtst and don't know if it translates to gtr. It certainly improves turn in.
What's it like on corner exit? oversteer or under? Possibly tighten the rear bar if it's understeering. That should also improve turn in
Give me the car for the Cup Day sprint :rolleyes:
I think a lot of the problem would be in the front ride height. There seems to be a trend with quick GTRs where their fronts are higher then rears. Also, maybe tray a track like Winton before getting too worried about it using the outside front right tyre. its naturally the case at an anti clockwise track like Sandown...but abit more camber would not hurt.
Thing is due you want it to be a nice road car that uses its tyres well, or a track car that looks after tyres at the track but eats tyres on the steet? Its hard to get a good compromise
probably want it to be a nice road car, but it does so few kms it's not a huge issue with camber tyre wear etc.
but still want it to be fun around a track at the same time
looks like the perfect setup - street and track friendly... it's the mirage
BHDave: thanks for the advice - my suspension guys reckon i should stay away from toe out for the moment b/c I'm a track spastic and the car can get twitchy. Corner exit it's a little understeery, probably a bit too much rear grip, it feels like it is pushing a bit
Rich: doesn't softening the front bar increase the roll and incidence of falling over the front right? thanks re castor - see above - I'm a spastic
I'm trying to get a pic of it coming onto the main straight to see how much it is pitching
yeah if you want it to be nice on track you need to man up and go with:
front toe out. at least 1mm each side, more if you are brave
front neg camber. 3 degrees will be nice.
soften front bar
stifen rear bar
bit more rear neg
and start playing with your endless combos of bump and rebound damping.
but it will be pretty average on road (unless you are well up it).
he just means late apex. we often get sucked into turning in to early. you really need to wait...wait...wait.. TURN IN NOW!
also with the GTR it really likes the slow in fast out approach. going in too hot means you will be moving around a lot under brakes and probably still trailing a little brake at turn in which is not good for business. I am majorly guilty of all these faults...and more.
so getting the thing slowed up enough before the corner, then tip it in nice and late, then on the power early may cure it. sometimes adjustment in driving style can negate some of the need for suspension change.
yeah mate. We of course aren't allowed to change anything on the race car except ride height, toe and tyre pressure - so as a result I always look at how I am attacking a corner first instead of trying to change the suspension.
gtr is a heavy car, has great traction and good power. All that together means brake hard, balance mid corner nice and smooth, then on the gas hard and early for corner exit, let the 4wd pull you out (4wd controller really helps a 32)
thats if the problem is mid corner and exit understeer. If its understeer on turn in try a little front toe out - it will make it feel a little twitchy but nothing dangerous. Rear toe out is a different story it can be exciting
Yep i have the same problem so going to try a little more agressive settings, different shocks, different bars, 350mm hight in front 340mm in rear. And if that dont work another pilot.
King of understeer signing out.
LOL here we go again.
Not the best pic but it is a banked corner at 16 degrees. I did purchase neg 5 degree cusco upper arms or so the package said?
Still it was just a mixed and matched set of suspenssion componants and car was to low and body roll was at an all time high.
going to correct that and be free of understeer forever :-) and yep damn pesky GT2 porker they are quick and light, handle well look good, cost grillions, chick magnet and i am going to spank it next time out :P
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
