Make: Nissan Skyline ER34 GTT
Model: 1998
Milage: 101,000K
Colour: Red
RWC supplied? Y
Currently registered? Y
Price: 22k
Contact: 0431424445
Comments / Modifications: In video
Pictures:
Edited by illusiVe
https://www.sau.com.au/forums/topic/191220-nsw-er34gtt-red-nismo-kit/
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
