nunawading engine clinic
to make thing even worse my car now has a f**ked coil pack (it didnt when i bought it in) so its running like absolute shit (worse then when i took it in for the service!!!) it is jittering at idle and power is struggling at low revs, after paying him $1200 he has made me wait a week to take it back and get it fixed.
the last thing i want to do is drive from tullamarine (work) to nunawdaing after a hard days work :)
STAY CLEAR OF THIS PLACE!!!@@
Their is a difference between a "service" and "fixing problems".
Best post in the thread.
Totally and UTTERLY depends on what needs fixing, most likely there are more problems than a reglar 100k service would cover.
Can anyone recommend any good places that they have had their cars at for the 100k service (in melbourne), mine is just around the corner and I would really like to take it to someone that can do the job quick, but at the same time keep it at a reasonable price and do a good job of it..
So what did you actually get changed? Some really rough prices are:
Timing belt - $200
Water pump - $150
Brake pads - $200
Fluids - $100
Spark plugs - $120 for platniums or whatever
Fuel/oil/air filters $100
Did you get the brake discs machined or replaced? machining - $100, replacement $500
So thats about a grand at least, without any labour...
It cost me about $500 to get my timing belt changed and new filters/fluids. No water pump, no brakes or anything.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
