ive been trying to sell mine for ages, no1 wants em :\ even for 250 $
I've had 3 people offer $200, and one offer $300 but he's not sure he can get postage.
Do yours have good tread etc?
if they were in W.A i'd buy them.
some cheap rims and tyres to burn up (legally of course) :(
send them to me for free?
ill pay for them.. i meant free postage.
For you, $550 and free postage will be included :glare:
i sold a set of mine for $200 with crappy tyres. they aren't highly desirable - but they are very very good cheap alternative for drag racing.
try selling on nissan silvia.
i would have kept mine if they cleared my big brakes.
Im not sure if the offset and stud pattern are the same.. but try the pulsar forums..
They look very similar to SSS wheels, fery wanted on the forums!
Thanks for telling me that mate.
I thought though FWD cars are 4x100, not 114.3?
Might be wrong though.. I'll ask a guy with a N14 I know.
I picked up a set of stockies for $50, but that was part of a trade deal for some extractors. I'd usually expect to pay $100 - $200 for rims excluding rubber.
I'm selling some 17x8" white six spoke rims - fit NA skylines perfectly
If you're interested check out some pics here: http://www.skylinesaustralia.com/forums/t189189.html
LOL greg.. Your always trying to pawn your shit off to us!..
Good luck with the sale mate :D..
And I may contact you within about a month or so for the zorst of yours.. :P
Edited by GTS4WD
Thanks :angry:
Honda Preludes and Accords early to mid 90s model are 4x114.3 offset 40+ fits fine...
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
