ive been trying to sell mine for ages, no1 wants em :\ even for 250 $
I've had 3 people offer $200, and one offer $300 but he's not sure he can get postage.
Do yours have good tread etc?
if they were in W.A i'd buy them.
some cheap rims and tyres to burn up (legally of course) :(
send them to me for free?
ill pay for them.. i meant free postage.
For you, $550 and free postage will be included :glare:
i sold a set of mine for $200 with crappy tyres. they aren't highly desirable - but they are very very good cheap alternative for drag racing.
try selling on nissan silvia.
i would have kept mine if they cleared my big brakes.
Im not sure if the offset and stud pattern are the same.. but try the pulsar forums..
They look very similar to SSS wheels, fery wanted on the forums!
Thanks for telling me that mate.
I thought though FWD cars are 4x100, not 114.3?
Might be wrong though.. I'll ask a guy with a N14 I know.
I picked up a set of stockies for $50, but that was part of a trade deal for some extractors. I'd usually expect to pay $100 - $200 for rims excluding rubber.
I'm selling some 17x8" white six spoke rims - fit NA skylines perfectly
If you're interested check out some pics here: http://www.skylinesaustralia.com/forums/t189189.html
LOL greg.. Your always trying to pawn your shit off to us!..
Good luck with the sale mate :D..
And I may contact you within about a month or so for the zorst of yours.. :P
Edited by GTS4WD
Thanks :angry:
Honda Preludes and Accords early to mid 90s model are 4x114.3 offset 40+ fits fine...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
