hey wat afc u got???
i thought of boughtin a power fc..but im not botherd either..i dont want to replace the stock ecu either..coz i only got a gtst..i got 243rwhp..so in kw's, dats lik 180..
so it cant b ur ecu..
my mods include..
3a racing pod,turbotech bleed valve @ 10psi, replica rs bov, front mount, splitfire coilpacks, re-gapped plugs to .65mm, HKS super drager cat-back exhaust, KYB damper adjustables coil-overs, apexi neo afc + tuned..
so yeah..i played around wit my afc alot..and im on my second tune already..lol
was using abit of fuel..so i lean out some settings..lik only to 0..lik i had some hi-throttle setting on +12 ??dont no y..so yeah..
and i run lik mid 13's to 14 flat..
plus i heard the stock nissan computer is really good!!
so i dont no..
dont think it would be ur ecu..
plus u got a upgrade turbo..
ur car probl. needs a beta tune?
or u gota problem somewer?
Edited by bumble_bee
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441420
my mods include..
so i dont no..
i have a manual safc, manual boost cont., splitfire coil pack, fmic, pod, 3inch dump and highflow cat to 3inch exahused, everything else is stock.
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441446
to run 180-190rwkw, i would want to have a aftermarket ecu or piggyback unit to keep everything under control.
I would also look at bigger injectors, as at 200rwkw you start to get close to 100% duty cycle, and possibly a better afm. (depending on what ecu you get, you might not require one).
if i was in your situation i would buy
Aftermarket ecu
electronic boost controller (if you haven't already got one)
free flowing 3" full exhaust.
550 injectors
But yeah the tuner is right by saying that a hiflow r33 turbo should be able to run more than 11psi. As the standard actuator on mine was able to hold 16psi.
with the mods i stated above, and a couple more, with my hiflow turbo i pushed 240rwkw on 16psi.
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441450
Aftermarket ecu
550 injectors
yeh i do plan to do all that, but dont have the cash right now. i only got the highflow turbo because i blow my stock one up and it was only 200 bucks more then another stock one(got it second hand cheap). im just hoping i can get by with what ive got for a month or 2 till i can afored the rest of the stuff i need. thanx mate.
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441470
yeah, could be anything
but looks lik afm, injectors, or ecu needs a good tune!
can u take it to another tuning place???
oh, check ur o2 sensor, i found on my second tune that mine died, so i replaced it myslef..
cost me $120 for a new gen. o2 sensor..
have u evan got a afc???
that would be the first piggyback system to get..
or evan an e-manage piggy unit..
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441482
i have a stock 33 gtst with just fmic, turbo back exhaust and boost controller set to 12psi and make 205rwkw....and power range is flat as a tack and runs a 13 flat....
so stock ecu, injectors, fuel pump can handle it....
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441491
Even the RB25 turbo on my RB30 is maxing the airflow meter just below 6000rpm.. I would guess that a hiflow on an RB25 is going to be maxing aswell.. if the ECU can't measure anymore air it can't throw in anymore fuel.. hence leaning out and pinging..
The stock ECU can only handle so much, if you start to go outside what it can measure/account for, then you need aftermarket management and bigger afm/injectors etc.
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441500
my mods include..
so i dont no..
man, what are you saying?????
with his mods, the standard computer is not really any good. He should be getting an aftermarket computer. Most likely he is hitting R & R, after the high flow install.
drifta: my advice is to make sure ur afm is not maxing out, check you coils/plugs and if the problem is not there, get an aftermarket ecu and then wind more boost into it. But then, you'd be looking to get bigger injectors and bigger afm.
Cheers
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441512
1. Get a decent ECU
2. Get a better AFM, or 1. with a map sensor
2. Get a decent Tune (from a new tuner, see comment below)
That will fix the problem.
Doing things 'on the cheap' im surprised you have not destroyed the motor already.
Pinging in the tune that is clearly heard... is a perfect example that the tuner should not be tuning. Its so sub-standard its not funny, so get a new tuner for the ECU setup
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441514
Cheers
hey check this out..
the stock ecu is good just needs to be tuned rit..
ive read many articles of people using the stock ecu upto 300rwhp..
here check this link out and read wat it says about the stock ecu..
http://speedworks.com.au/products/bikirom/bikimain.html
so he shouldnt hav a problem here...
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441551
13-14psi boost on a highflow is not at all the same as 13-14 stock. that is your only problem. for sure the ecu is getting afm signals which make it say "WTF??". turn the boost down and try again
ive had stock ecus pinging and retarding timing at 12psi and up on stock turbo. to attempt it with a highflow is a bit stupid without any other engine management
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441803
hey just from reading the original post it doesnt sound like an ecu issue. change the crank angle sensor on the front of the motor. that is more likely to be the issue, if that fails then good luck ,).
i would be almost certain thats the issue
dude i think your on the ball because my tuner said the same thing, he ran out of time to try it but its going bk tommorow so hopfully ur right. thanx mate.
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441853
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
