  • Replies 97
this car is still or sale?
you got PM
PM Replied To , As i have Mentioned somebody has left a deposit but he cannot get funds until April so i have told him if it sells before then then it sells ....
Hey MRGTR911. I have a 2005 BMW M3 SMG convertible if youre interested......Carbon black with lipstick interior. Done 15km. Not interested in your GTR32 car as I have an NUR GTR34 now, but if you end up selling both your GTR34 and 32, give me a pm. As Im thinking of selling the M3 for the new one, or possibly an AUDI S5 or RS4.
PM SENT ;)
Hi,
Im Interested in your GTR just a couple a questions though i was just wondering if you still have the rear interiour seats / pannels, and how hard would it be to take out the half cage? Also would there be any visable wholes after the cage is out and the stock interiour back in. Just asking this because the car would have to have a ID check to get Rego in SA and i dont think that would go down too well with the police over hear. Thank you for taking the time to reply.
Regards
Brenton
Hi,
Regards
Brenton
Hey Mate i do not have the Rear seats you will have to Rip the Rear Part of the interior Then you can Put the rear Seats In , As for the Roll Cage It Is Bolted in It will take you no More Then 15 Minutes to pull it apart as i have pulled it Apart a Couple of Times , Once you do pull them apart and you put the interior In there will be no Visible Holes , As the Interior has covered it all . I Must ask you why you want to put the interior so many people have asked me this Question i Honestly rekon its looks more tough with the cage, I Paid $700 To get that Roll Cage Engineered , And Paid alot to get the rest of the Car Engineered , So car is Fully Street Legal , And if you decide to hit the track one day the cage is in there.... Up to you anyway ...
Good luck ...
Yea i reckon its tuff as too but the only problem is Jonny Law behind you can see the cage and that gives him a excuse too pull you over, and then bend you over. As im not sure how i will go with it being engineered in NSW compaired to SA as you have more relaxed laws compaired to us here in SA where our road traffic laws are very strict on such items.
Ok i understand your lws are tough , But i have taken my papers To the RTA And they have approved the car as being Fully Road Legal , So i think if you took all the Papers i have to your local RTA Im sure they can do something For you, I didnt spend all the Money get it enginereed for Nothing ? I Honestly thought sydney was the worst for these kind of laws . Ill tell you one thing Ever since i got all my RTA Paperwork sorted out to make it fully legal , I Have been pulled ovr by atleast 7 Highway Patrol Cars In the Worst Areas of Sydney , And every single one that pulls me over has a look through the papers checks Information on there database And simply tell me your right to go ....
i own a bmw e36 m3 3.0L 5spd if you interested in trades..
im currently in market for a rb26 powered gtr too. >_<
Hey Mate ,
If its a 05,06,07 Model i would of taken it , Pm's Replied to , The Guy who left a deposit on this Car has pulled out he was a time waster, But i kept his $400 deposit :-) , So if anyone is still interested its still for sale, Ill keep driving it around until then :D
Well done
Thanx mate it was a hard decision i was having second thoughts. The guy who bought it is going to have alot of fun ill tell you that .. I Am now on the hunt for Another R34 GTR ... FLYT-34 Coming soon .
Guest
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
