Remove the dashboard – R33
Personally i havent tried this, but hope this may give some people an idea.
Pull out ashtray and remove two screws from behind. Carefully pull up gear shift surround, remove cigarette lighter and light plugs, and move as far to one side as possible.
Remove 2 screws that were hidden by the gearshift surround. Remove 6-7 screws (cant remember exactly how many) from underneath the steering wheel column, as you will need to remove the plastic surrounds in order to remove the dash.
Remove plastic surrounds around steering column. CAREFULLY, and I mean carefully ie by levering up in the best places so it doesn't cause it stress, remove the dash and centre console. Its all in one piece, and you will have to unplug the demister switch, hazard lights switch, clock, air-con sensor and pipe, and electric mirror controls.
There should now be a further 4 screws that are holding the centre stereo and air-con bracket in place. These can be removed and the entire bracket removed.
https://www.sau.com.au/forums/topic/191322-remove-the-dashboard-r33/
  • 1 year later...
