I have an 040, it was a pretty simple job, you just need to get a hose clamp to hold it onto the pump cradle base. I haven't had any changes to my fuel consumption which would lead me to believe my A/F ratio hasn't changed.
https://www.sau.com.au/forums/topic/191347-040-into-stagea/#findComment-3443979
:D hey i got an o44 in mine just need a big hose clamp and a few speed flow fittings to addapt a sock to the pick up and a dash 6 right angle to the out let so it will clip into the base properly again. if you stuff it up i have 2 spare cradles in my shed . also got a r32 gtr pump which will go in to if you dont wanna modify anything .cheers bernard.
https://www.sau.com.au/forums/topic/191347-040-into-stagea/#findComment-3444287
isnt the 044 a direct fit?
Nope, not a direct fit - I bought one and it couldn't be fitted. I've compared it to the standard factory pump, and the 044 is almost double the size.
Best bet is (probably) a Walbro upgrade pump or the Nismo pump - at least they'll come a lot closer to being a direct fit. The Walbro, if purchased from Unique Autosports, comes with a fitting kit to make it easier.
https://www.sau.com.au/forums/topic/191347-040-into-stagea/#findComment-3444318
just be careful with the walbro, make sure they check flow all the way up to redline. I put one in and it ran out of flow up high, very dangerous - and have heard of others having this problem too.
nick, I am surprised they couldn't fit the 044, maybe take it to someone a little more creative/adventurous.
https://www.sau.com.au/forums/topic/191347-040-into-stagea/#findComment-3452436
I have a dyno sheet and the AFR's stayed nice and stable all the way through, so the Walbro looks to be doing its job. The car dropped 10kW at the wheels because it now receives the right amount of fuel, but at least I won't have to worry about issues with leaning out.
I was surprised they couldn't put in either, Duncan! It IS a fair bit bigger, as I mentioned (I will post photos comparing the 044 to the factory unit), but I assumed they would have taken that into account and sort something out. Oh well...
Oh, have you got a PFC for yours yet, and if so which one (R33 or R34)?
https://www.sau.com.au/forums/topic/191347-040-into-stagea/#findComment-3453492
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
