Dyno Day
67 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey ppls,
Due to other dyno days being held around the same time SA/SAU usual holds their the Annual SA/SAU Dyno day hasn't been held. Its great for a checkup of how the cars running and mix it up with a few other SAUer's.
DETAILS:
BOOSTWORX - 57 Boothby Street, Panorama
TIME: Saturday 8th of March - 10:00am :- So get there 10mins early POSTPONED
The cost of the dyno day is $30 for 2 dyno runs and a print out.
A BBQ and refreshments will be provided charged very reasonably per snag and drink
Please do note there has recently been a little hoon activity within the area (which is believed to be related to the TAFE); Boostworx has been targeted as the possible offender; so please no burnouts or hooning through the sidestreets.
The plan is it will also be the first day of accepting SA/SAU club memberships which will be cams affiliated.
No prizes etc as the dyno runs are provided at cost - Makes it fair for the near stockers.
There's no limits on what cars can be run on the dyno; bring your old banga for a laugh if you wish. As long as your an SAU thats all that matters.
So.... Who wishes have a run on the rollers on the day and possibly buying a snag or two?
01. Darkhorse - PAID
02. Vietorious - PAID
03. Salad - PAID
04. RB_Man - PAID
05. matty_31 - PAID
06. Nightcrawler - PAID
07. Dangerman4 - PAID
08. rd-runr - PAID
09. sambo33 - PAID
10. RB25DETS2 - PAID
11. 93R33 - PAID
12. wegs - PAID
13. J_Red33 - PAID
14. 180or200- PAID
15. Hotwire
16. Deluxe
17. AfterGlo
18 32_4whore
19. Heslo
20. Advent34
21. bezender
22. rad510
23. writeoff
24. dnbutts
25. AFTDRK
26. ryanrb25
27. gzilla
28. barricade
29. gtrkiet
30. natoe aka slw 031 - PENDING
31. SICKR33GTS-T- PENDING
32. Cubes - PAID
Now accepting payment to secure your place and choice of when you wish to run.
Remember its cooler in the morning. :P
We have the minimum 10 upfront payments to go ahead; if you wish to secure your spot and have a choice in when you wish to run get your payment in.
PM me for bank deposit
TIME: 8th of March 2008 - 10:00am so get there 10mins early.
AND FOR THE RESULTS...
https://www.sau.com.au/forums/topic/191361-sasau-30-dynobbqclub-day/
  • Replies 326
Posted Images
Will this be at Boostworx again? Is January an ideal time to run a dyno day? It will probably be pretty damn hot. I'd say April/May would be better although with current climate patterns - or lack there of - it may be cooler in January. I'd prefer the 19th as I usually have something on Australia Day.
Yes It will be at Boostworx again. Boostworx have the best price for a dyno day.
Myself I'm not too keen on spending $50 for a power run that some of the other dyno operators are charging when all you receive is a laminated dyno sheet with possibly a picture. GW does both 2wd and 4wd $40 and $50 respectively but $10 is $10.
I feel $30 is quite reasonable. A BBQ and Cold drinks will be available; Boostworx also has evap aircon so there will be plenty of air movement.
If the weather is possibly hot/warm it could be a really good time to hold a dyno day depending on how you look at it.
Its always good to have the car on the dyno during hot weather as you are able to find out how it runs in such conditions.
Is it pinging. Is it safe to give it a bit of a boot during hot weather?
So for those of you that don't have the car run up both in cold and hot weather it will be a good chance to see if the car is running well.
However... If the majority would like the day to be held a little later by all means it can be done. :P
I personally don't mind the idea of a warm dyno day as its a good check up.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
