Dyno Day
67 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey ppls,
Due to other dyno days being held around the same time SA/SAU usual holds their the Annual SA/SAU Dyno day hasn't been held. Its great for a checkup of how the cars running and mix it up with a few other SAUer's.
DETAILS:
BOOSTWORX - 57 Boothby Street, Panorama
TIME: Saturday 8th of March - 10:00am :- So get there 10mins early POSTPONED
The cost of the dyno day is $30 for 2 dyno runs and a print out.
A BBQ and refreshments will be provided charged very reasonably per snag and drink
Please do note there has recently been a little hoon activity within the area (which is believed to be related to the TAFE); Boostworx has been targeted as the possible offender; so please no burnouts or hooning through the sidestreets.
The plan is it will also be the first day of accepting SA/SAU club memberships which will be cams affiliated.
No prizes etc as the dyno runs are provided at cost - Makes it fair for the near stockers.
There's no limits on what cars can be run on the dyno; bring your old banga for a laugh if you wish. As long as your an SAU thats all that matters.
So.... Who wishes have a run on the rollers on the day and possibly buying a snag or two?
01. Darkhorse - PAID
02. Vietorious - PAID
03. Salad - PAID
04. RB_Man - PAID
05. matty_31 - PAID
06. Nightcrawler - PAID
07. Dangerman4 - PAID
08. rd-runr - PAID
09. sambo33 - PAID
10. RB25DETS2 - PAID
11. 93R33 - PAID
12. wegs - PAID
13. J_Red33 - PAID
14. 180or200- PAID
15. Hotwire
16. Deluxe
17. AfterGlo
18 32_4whore
19. Heslo
20. Advent34
21. bezender
22. rad510
23. writeoff
24. dnbutts
25. AFTDRK
26. ryanrb25
27. gzilla
28. barricade
29. gtrkiet
30. natoe aka slw 031 - PENDING
31. SICKR33GTS-T- PENDING
32. Cubes - PAID
Now accepting payment to secure your place and choice of when you wish to run.
Remember its cooler in the morning. :P
We have the minimum 10 upfront payments to go ahead; if you wish to secure your spot and have a choice in when you wish to run get your payment in.
PM me for bank deposit
TIME: 8th of March 2008 - 10:00am so get there 10mins early.
AND FOR THE RESULTS...
https://www.sau.com.au/forums/topic/191361-sasau-30-dynobbqclub-day/
  • Replies 326
Posted Images
Will this be at Boostworx again? Is January an ideal time to run a dyno day? It will probably be pretty damn hot. I'd say April/May would be better although with current climate patterns - or lack there of - it may be cooler in January. I'd prefer the 19th as I usually have something on Australia Day.
Yes It will be at Boostworx again. Boostworx have the best price for a dyno day.
Myself I'm not too keen on spending $50 for a power run that some of the other dyno operators are charging when all you receive is a laminated dyno sheet with possibly a picture. GW does both 2wd and 4wd $40 and $50 respectively but $10 is $10.
I feel $30 is quite reasonable. A BBQ and Cold drinks will be available; Boostworx also has evap aircon so there will be plenty of air movement.
If the weather is possibly hot/warm it could be a really good time to hold a dyno day depending on how you look at it.
Its always good to have the car on the dyno during hot weather as you are able to find out how it runs in such conditions.
Is it pinging. Is it safe to give it a bit of a boot during hot weather?
So for those of you that don't have the car run up both in cold and hot weather it will be a good chance to see if the car is running well.
However... If the majority would like the day to be held a little later by all means it can be done. :P
I personally don't mind the idea of a warm dyno day as its a good check up.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
