Dyno Day
67 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey ppls,
Due to other dyno days being held around the same time SA/SAU usual holds their the Annual SA/SAU Dyno day hasn't been held. Its great for a checkup of how the cars running and mix it up with a few other SAUer's.
DETAILS:
BOOSTWORX - 57 Boothby Street, Panorama
TIME: Saturday 8th of March - 10:00am :- So get there 10mins early POSTPONED
The cost of the dyno day is $30 for 2 dyno runs and a print out.
A BBQ and refreshments will be provided charged very reasonably per snag and drink
Please do note there has recently been a little hoon activity within the area (which is believed to be related to the TAFE); Boostworx has been targeted as the possible offender; so please no burnouts or hooning through the sidestreets.
The plan is it will also be the first day of accepting SA/SAU club memberships which will be cams affiliated.
No prizes etc as the dyno runs are provided at cost - Makes it fair for the near stockers.
There's no limits on what cars can be run on the dyno; bring your old banga for a laugh if you wish. As long as your an SAU thats all that matters.
So.... Who wishes have a run on the rollers on the day and possibly buying a snag or two?
01. Darkhorse - PAID
02. Vietorious - PAID
03. Salad - PAID
04. RB_Man - PAID
05. matty_31 - PAID
06. Nightcrawler - PAID
07. Dangerman4 - PAID
08. rd-runr - PAID
09. sambo33 - PAID
10. RB25DETS2 - PAID
11. 93R33 - PAID
12. wegs - PAID
13. J_Red33 - PAID
14. 180or200- PAID
15. Hotwire
16. Deluxe
17. AfterGlo
18 32_4whore
19. Heslo
20. Advent34
21. bezender
22. rad510
23. writeoff
24. dnbutts
25. AFTDRK
26. ryanrb25
27. gzilla
28. barricade
29. gtrkiet
30. natoe aka slw 031 - PENDING
31. SICKR33GTS-T- PENDING
32. Cubes - PAID
Now accepting payment to secure your place and choice of when you wish to run.
Remember its cooler in the morning. :P
We have the minimum 10 upfront payments to go ahead; if you wish to secure your spot and have a choice in when you wish to run get your payment in.
PM me for bank deposit
TIME: 8th of March 2008 - 10:00am so get there 10mins early.
AND FOR THE RESULTS...
https://www.sau.com.au/forums/topic/191361-sasau-30-dynobbqclub-day/
  • Replies 326
Posted Images
Will this be at Boostworx again? Is January an ideal time to run a dyno day? It will probably be pretty damn hot. I'd say April/May would be better although with current climate patterns - or lack there of - it may be cooler in January. I'd prefer the 19th as I usually have something on Australia Day.
Yes It will be at Boostworx again. Boostworx have the best price for a dyno day.
Myself I'm not too keen on spending $50 for a power run that some of the other dyno operators are charging when all you receive is a laminated dyno sheet with possibly a picture. GW does both 2wd and 4wd $40 and $50 respectively but $10 is $10.
I feel $30 is quite reasonable. A BBQ and Cold drinks will be available; Boostworx also has evap aircon so there will be plenty of air movement.
If the weather is possibly hot/warm it could be a really good time to hold a dyno day depending on how you look at it.
Its always good to have the car on the dyno during hot weather as you are able to find out how it runs in such conditions.
Is it pinging. Is it safe to give it a bit of a boot during hot weather?
So for those of you that don't have the car run up both in cold and hot weather it will be a good chance to see if the car is running well.
However... If the majority would like the day to be held a little later by all means it can be done. :P
I personally don't mind the idea of a warm dyno day as its a good check up.
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
