Hi people, I am in need of some advice & hope somebody can help me make the right decision...
I am waiting on a set of HKS2530's to come in from Japan. I have been waiting a while so I been doing a few basic things in order to get the most efficiency & performance out of my setup.
Upon the advice of a local tuning shop, I had the manifolds match-ported to the head & had the outlets ported out to be the full size of the gasket that goes between the turbo & the manifold. Since then the manifolds have been ceramic coated.
The issue is that I was looking at some pics of the turbos in a magazine & it appears that the exhaust inlet on the turbos is the same size as the factory ones (not larger as I was told, but I will have to confirm this once the turbos arrive), meaning that I should have left this side of the manifold alone...
I need some advice on what to do from here. The way I see it my options would be:
1. To port out the inlet on the turbo to match.
2. To use another set of manifolds.
3. Just bolt it all up & don't worry about it
Any advice appreciated.
*Note to self - be patient & check things before you modify them!*
Regards,
Mike.
This is something that I was looking at a while back.
I came to the conclusion that it probably isnt really all that necessary, as turbine housing itself is alot more restrictive than the manifold.
As long as there are no rough edges anywhere, and every joint meets seemlessly (ie manifold to turbine matched) that is about all you can do without increasing the AR ratio - which will of course effect where in the rev range the turbos operate at peak efficiency.
It may be possible to extrusion hone the turbine housing, with out effecting the AR ratio overly, but the size of the inlet to the turbine housing itself, if its larger than the path the gasses has to follow as they travel through the turbine, should be fine.
Does that make sense?
Just to qualify, this is all I have found from research, so its possible that like so many other things, paper and the real world differ:D
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
