ok i had the misfiring problema nd it was fixed with regapping sparkies to 0.8mm... but now its missing still but only when the ambient temperature is really low (ie. at night.. like tonight) ios this still the sparkies or coiul packs or just i have to accept i cannot go hard on real cold nights ? i thought the colder the better ? hmm
im getting a powerfc etc done soon will they have tp check all of this out anywyas ? coz im going back to stock boost etc tomorrow until i get he pwoerfc shoujld i just wait until then and get everything setup perfect ?
https://www.sau.com.au/forums/topic/19139-missing-on-cold-nights/
i had that problem, thought it was a miss. What was happening was that on colder nights the boost creeps just enough higher to hit the factory boost cut, and id get a couple of pops while revving it out. as soon as the day got warmer it disappeard. On cold nights i just turned to boost down a touch and it was fine. Now i have PFC and no longer a prob.
what boost are you running? this is probably your problem.
PS- DJ, your car looks f'in sick! what bar you got on the front? cant really see from the pic. And what are those wheels?
ONLY RUNNING 10PSI lol
uh the wheels are some jap ones with carbon fibre coating :D and the front bar is a 'modded' standard mspec one with a huge mouth for my huge cooler lol as in the attachment
*sigh* i guess ill just wait until i get a powerfc :) should only be acouple weeks max
Its typical for an engine to run leaner on cold nights, as the air is denser. But one great thing with modern ecu's, they have temp sensors which are supposed to adjust the fuel accordingly. This probably doesnt relate to you car but i remember reading in zoom that anything like an intercooler could upset the AFM.
The main reason why our old carbie-fed cars did not run well in cold weather even with the choke on is because there is not enough energy in the spark to ignite the fuel mixture.
This can be directly because the ignition coil wasn't up to the task, or more commonly, because the carbie is not atomising the fuel enough. ie, cold fuel clumped together is much harder to burn than a fine mist of warm fuel. So you could fix it by either cleaning or re-jetting your carbie for better atomisation, or getting yourself a higher energy ignition system.
Try cleaning your injectors and checking your spark voltage. I'm not sure how you'd do the latter, so start with some injector cleaner in the tank and see what happens.
Also maybe check your TPS, it could be a mixture issue.
Originally posted by SLY33
looks neat, do you ever get done for no front number plate?
not yet.. only been off for about a week.. i ordered a really small one to be mount4ed to the side and i cbf putting the large one on temporarily :) ill just say its stolen :D
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
