DUDE what lens are you using for those long exposure shots??
I love it!!!
i wanna get into photpgrahy and thinking off getting a 400d (canon)..
perhaps you can help me out: http://www.nissansilvia.com/forums/index.p...howtopic=267342
Thats my thread there..
https://www.sau.com.au/forums/topic/191393-my-photography/#findComment-3446056
Nice work, the skyline is my favourite...
Couple of suggestions though:
* Generally skylines should stay horizontally level
* 10 seconds in Photoshop is your friend with any digital photo
I did a Rotation, Lens Correction, Resize and Sharpen and came up with this:
-Greg.
will update everyday
https://www.sau.com.au/forums/topic/191393-my-photography/#findComment-3458677
-Greg.
cheers mate but i dont like to photoshop the photos . i like them how they are :)
https://www.sau.com.au/forums/topic/191393-my-photography/#findComment-3470476
Photoshop is pretty much essential with digital photography. Just like a darkroom to film users.
When I 1st started shooting digital I didn't like the idea of using photoshop either. Aswell as not being able to use it.
Now I wouldnt have it any other way. I love it.
Edited by Lepperfish
https://www.sau.com.au/forums/topic/191393-my-photography/#findComment-3479872
  • 2 months later...
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
